Home > Maintenance & Modifications > School me on rear towing/recovery point options - so many!
Page 4 of 5 <12345>
I'm always puzzled as to why anyone would want to use JATE rings for recovery, particularly on the rear. Regardless of whether they're strong enough, they're in an awful position if the vehicle is bogged down in mud or sand. Far better to use something suitable bolted to the rear cross member, IMHO. Darren
Post #694007 17th Mar 2018 11:18am
Bluest
In my previous job I was trained to and had to carry out emergency recovery of accident damaged vehicles. We had to use an electronic load cell that would alarm if the force on the tow hitch exceeded a pre determined safe figure ( different depending on the tow vehicle model). That allowed us tow quite large, or badly damaged vehicles using a jaw and pin on a standard tow bar. In even a very straight forward recovery, a ham fisted approach could easily trigger the alarm so you soon become adept at being smooth, and applying loads gently and maintaining a steady tension as far as possible.
The forces involved in trying to snatch recover a heavily bogged vehicle would likely be an order of magnitude higher than the trigger point on our load cells, and could easily damage towing points and vehicle chassis quite severely. I wouldn’t attemp it simply because I don’t actually know where on Defender is strong enough for that kind of load. I’d want someone who had done research, and had the skills to take me through it. 2007 110 TDCi Station Wagon XS
Post #694010 17th Mar 2018 11:21am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
leeds wrote:
If people want to get an idea about forces involved in recovery have a read of Billy Vista Recovery Bible here
Now I do not expect people to get the calculator out and remember the various components of the formula every time they attach a winch/recovery strap.
Yes forces can be 3 times vehicle weight so kit and recovery points plus technique need to be up to the job in hand.
If doing a 'snatch' type recovery rather then a steady pull i.e. winch etc, that peak F= Ma (Force = mass x (de)acceleration) so selection of material/equipment is important.
Brendan
Brendan,
It's pretty much that advice which guided me to the product on your store. As it's for occasional use I can't justify the option that agent mulder has gone for (despite how tidy it looks). As it's a standard 110USW with the 3 times vehicle weight was pretty much within the rating of that recovery point, although if I've got the maths wrong I'm happy to be corrected.
Thanks
Keith Keith
Post #694054 17th Mar 2018 2:15pm
Mo Murphy wrote:
That's a really cool pic Very Happy Thumbs Up
Mo
No - it's an OK pic...
this is a really cool pic Laughing
If you have JATE rings fitted then a Chinook is cleared to recover you...don't bother asking if you have nice shiney laser cut & polished bits you bought off a bod on the internet Thumbs Up
Post #694278 18th Mar 2018 10:43am
agentmulder
Kuwait
I forget what we were talking about.
Jacking points on our Chinooks? Solved the bowel problem, working on the consonants...
Post #694284 18th Mar 2018 10:53am
Paul1275s
United Kingdom 2003 Defender 110 Td5 SW Belize Green
Supacat wrote:
Mo
Falkland Islands? 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #814177 8th Feb 2020 12:44pm
It's not my photo so I don't actually know. It does like it could be. Might be worth a bit of Internet sleuthing to see if the original source can be found...
Post #814184 8th Feb 2020 1:56pm
markb110
When marshalling in the past I found in some situations the Jate rings were jammed solid against the chassis rail .
The reason was that the owners did not like the noise of them slapping around so tighten up the bolts.
If you do choose to fit them please make sure that they will move easily before you need them Thumbs Up
Keep your marshal happy, you know it makes sense.
This has been a public service announcement......
Post #814185 8th Feb 2020 1:57pm
markb110
This was my South down tank guard with NATO hitch on my previous Defender....
Post #814187 8th Feb 2020 2:14pm
More JATE ring action:
1 Air Mobility Wing RAF #StayHomeSaveLives (@1AirMobWing) Tweeted:
Our Movements Conversion Unit (MovCU) have been busy today assisting @24SqnRAF with some EROs (Engine Running Offload) in some vital collaborative training. Used to minimise ground time it is essential we practice this at home so it can be achieved when needed. #WeAre1AMW ✈️ 💪 https://t.co/O4tqPg08vY https://twitter.com/1AirMobWing/status/1252642188229586945?s=20
Post #826959 22nd Apr 2020 6:35am
mikeh501
agentmulder wrote:
The eventual solution:
Thumbs Up
far and away the best solution for rear recovery imho.
jate rings sound great until you need to crawl under a vehicle in mud and/or water to find them. avoid.
Post #826977 22nd Apr 2020 8:22am
If you want to keep everything clean and tidy best stay away from off-roading altogether...you're missing half the fun...
Post #826980 22nd Apr 2020 8:32am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Paul1275s wrote:
Supacat wrote:
Mo
Falkland Islands?
Yes, some time in the 80s I believe, when they were building Mount Pleasant Airport. No Chinooks here now Sad ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #827010 22nd Apr 2020 10:47am
More JATE rings...
https://www.facebook.com/groups/PostWarMil...167923968/
Think Defence (@thinkdefence) Tweeted:
Which will go out of service first? https://t.co/LN748aFZw5 https://twitter.com/thinkdefence/status/1264604850777657345?s=20
Post #832519 22nd May 2020 5:48am
AndrewS wrote:
Please don't use Jate Rings for off road recovery. Have a look to see what fixes a Jate Ring to the vehicle and you will see why they are not suitable.
They are simple lashing points.
And what I hope is a source that can be trusted to know exactly what a JATE ring is:
Post #846789 29th Jul 2020 6:33am
Page 4 of 5 <12345>
