Home > Maintenance & Modifications > School me on rear towing/recovery point options - so many!
Page 3 of 5 <12345>
AndrewS wrote:
Please don't use Jate Rings for off road recovery. Have a look to see what fixes a Jate Ring to the vehicle and you will see why they are not suitable.
They are simple lashing points.
This looks well lashed:
Thumbs Up
Post #693773 16th Mar 2018 2:25pm
Mo Murphy
That's a really cool pic Very Happy Thumbs Up
50 Shades of Pennine Grey
Post #693795 16th Mar 2018 4:50pm
agentmulder
Kuwait
The eventual solution:
Thumbs Up Solved the bowel problem, working on the consonants...
Post #693832 16th Mar 2018 7:27pm
zsd-puma
Thumbs Up
Exactly. JATE actually stands for Joint Air Transport Establishment. So long as you use quality forged rings they're plenty strong enough for recovery. The front mounting points are deliberately double plated for them. The rears should have a tube welded into the chassis rail, but not all civilian chassis have this from the factory.
Post #693839 16th Mar 2018 7:38pm
agentmulder
Kuwait
Memory is funny but I could have sworn that the jate rings on my mates 110 interfered with his rear mud guard bracket...
Edit: also, I can imagine recovery forces being more than the mass of the vehicle/4... and at more extreme angles...
Not saying yay or nay, just sayin... Solved the bowel problem, working on the consonants...
Post #693842 16th Mar 2018 7:43pm
mikeh501
agreed, the forces involved in recovery can be much much that just a straight pull.
Also, I doubt that landie under the chinook is using the same jate points under the vehicle. wouldnt be very stable!!
Post #693851 16th Mar 2018 8:10pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
The JATE rings are fitted to military Wolfs for the main reason of heli lifts as shown, new modifications have come out and a dual set of JATEDU rings with additional strength plates welded on the rear are now in place for vehicles that are carried by this method often. There was an article in LRO/LRM a while back Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #693895 16th Mar 2018 9:51pm
You have obviously never seen a chinook pilot use the full operating envelope whilst carrying an underslung load - the forces generated are more than the static load/mass of the vehicle.
I'm really puzzled as to why anyone would want to put more trust in an online seller of a lump of laser cut unidentified steel than a product that has been designed & tested for vehicle specific military applications where the outcome of a failed load is far more than a red face.
Maybe if they came in bright colours, was more sparkly or had more pub bragging rights; instead they just do the job, no fuss, no effort & not particularly expensive.
Post #693945 17th Mar 2018 7:42am
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Thumbs Up
That does look smart Thumbs Up I'm very tempted by one to replace my plow Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #693952 17th Mar 2018 8:28am
agentmulder
Kuwait
Well, Brendan 'identified' it and that was enough for me. Sometimes you just gotta trust things right?
... and like I said, the last time I saw JATE rings installed they appeared to clash with the mud guard brackets of the vehicle in question.
I did want it in high-vis, first responder livery so people would think I was a champ but they only had bulk/batch/discount-dark-grey available - otherwise known as 'tactical' Laughing Solved the bowel problem, working on the consonants...
Post #693958 17th Mar 2018 8:52am
agentmulder
Kuwait
The drop plate is still a major plow when it's on! But it lives in a box in the rear now along with the shackle and billet/point so it's even less fussy Thumbs Up Thumbs Up Solved the bowel problem, working on the consonants...
Post #693959 17th Mar 2018 8:56am
Apparently it is...this is the current (2015) version:
Post #693961 17th Mar 2018 8:59am
I've seen them fitted to the front of Vixens but can't find a photo of the rear arrangement:
but the loading sheet for it shows that only one of the two Jate rings is used:
and again with the RWMIK Plus:
Don't suppose you have the article still?
Searching through my documents, I've found the Modification Instruction for the double Jate rings and it states: "This instruction details the fitting of additional lashing eyes to the front bumper and to the rear chassis rail. This modification is only applicable to those units who would be considering transporting the equipment as internal load by Air."
Post #693973 17th Mar 2018 9:41am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Has anybody fitted one of these? I'm keen to see an installed photo.
http://www.4x4overlander.com/product/defen...ery-point/
Thanks Keith
Post #693979 17th Mar 2018 9:55am
leeds
If people want to get an idea about forces involved in recovery have a read of Billy Vista Recovery Bible here
Now I do not expect people to get the calculator out and remember the various components of the formula every time they attach a winch/recovery strap.
Yes forces can be 3 times vehicle weight so kit and recovery points plus technique need to be up to the job in hand.
If doing a 'snatch' type recovery rather then a steady pull i.e. winch etc, that peak F= Ma (Force = mass x (de)acceleration) so selection of material/equipment is important.
Brendan
Post #693989 17th Mar 2018 10:31am
Page 3 of 5 <12345>
