Home > Maintenance & Modifications > Electronic Rust Protection
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
After scouring the web for a while to try and find something which constantly fights rust, I came across this http://www.rustguardian.co.uk/. It seems abit too good to be true, has anyone had any experience with it?
Thanks
Jack
Post #69148 30th Apr 2011 9:43pm
spudfan
Ireland
1989 Range Rover brochure RR504 states-Electrophoretically corrosion proofed welded box section chassis.
Much the same principle I think yet Land Rover stopped doing it. Maybe it was a cost cutting exercise or maybe it just was not up to the job. Any 1989 Range Rover owners out there want to coment? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #69156 30th Apr 2011 10:48pm
FLINTSTONE
Australia 2009 Defender 110 Puma 2.4 SW Zermatt Silver
look up www.couplertech.com.au
Had it on the truck since 98, it works.
Done alot of beach work. No rust.
Flinty
Post #69159 1st May 2011 12:05am
Kez
Isle Of Man
No mention of cost, always a warning sign to me :-/
Post #69202 1st May 2011 2:37pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Yes they work on boats, but as your Landrover is not a boat then it won't work. Something to do with being submerged to allow the electrical circuit to complete. Google it.
Electronic rust protectors use a technique called Cathodic Protection where a flow of electrons is forced through the metal which brings it closer to an immune state and reduces the metal’s corrosion potential. Cathodic Protection can only work if there is a complete electrical circuit to bring back electrons. That’s why these devices can work for boats, bridges, pipelines and etc., since there is a pool of ions surrounding the metal to conduct electricity and to close the circuit. So, unless you bury your car or submerge it in water, these electronic rust protectors cannot possibly work for cars (remember that all the metal to be protected needs to be surrounded by free electrons so it’s not as simple as grounding your car)
taken from here---- http://www.corrosion-doctors.org/Car/car-electronic-rust.htm
don't waste your money.
Post #69206 1st May 2011 3:07pm
Caterham
I need to find out some more on this myself to do with work - and I don't work with boats but buildings.
the reason I need to find out somemore is due to one of the buildings I'm involved with has this type of protection (cathodic protection) for the steel reinforcement within the concrete / structure. also the window frames are bonded into the circuit?
Post #69207 1st May 2011 4:00pm
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
I made an enquiry on their site over the weekend and a friendly guy called me this morning. In short, he said the product didin't need a complete circuit - bury in ground or in water to work. He did explain it to me but after 3 minutes I kinda drifted off having flash backs of 6th form college physics lessons.... as you do Big Cry
£199.99 + vat + delivery per unit. Made in China for an Australian company. They also sell a clear coating system which has some interesting references to Land Rover! - looks like an alternative to Waxoyl.
I had an email sent to me with several attachments on the products they offer. If anyone is interested, PM me your email address and I will forward. It's 3mb worth - .pdf's and Word docuemnts. Various techy stuff and case studies etc.
I'm not trying to flog it... I was just mildly interested at the time Rolling with laughter
Post #69479 3rd May 2011 11:10am
Lorryman100
PM sent, cheers Thumbs Up
Post #69490 3rd May 2011 12:21pm
dgardel
Italy
My dubts are about the Steel/alloy Defender mix...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #69493 3rd May 2011 1:33pm
