Home > Maintenance & Modifications > Twin spare wheel carrier
Page 1 of 4 1234>
BigMike
Does anyone know of one? Second can't go on the roof (Magiolina on there) or the bonnet, or the side panels as its a SW.
I've seen twin arms for a landcruiser but a defender is narrower and it wouldn't work I think. The new safari equip carrier might be able to be modded and I'm going to discuss that with them but just wondering if anyone knows of a firm that does one, or one which could be modded successfully. I don't mind if the rear view is obscured.
Post #69109 30th Apr 2011 4:56pm
BigRuss
I think kaymar do them in oz. Russell
2011MY 110 XS USW Black
Post #69130 30th Apr 2011 6:54pm
BigMike
Cheers Russ, had looked at them, they only do them for discos, not defenders.
Post #69132 30th Apr 2011 7:04pm
BigRuss
Ok then, have you tried frogs island 4x4? There are some photo's in their gallery showing them fitted. Russell
Post #69133 30th Apr 2011 7:15pm
BigMike
fabulous, cheers. on the kaymay site it specifically says single only. but the fitting on the frogs site looks exactly like the kaymar one? anyway, will ring them on tues, many thanks.
Post #69135 30th Apr 2011 7:23pm
discocuzzy
I think they are a pair of single Mike, right and left handed, saw a few of them in South Africa mounted on a custom bumper to accomodate the twin pivots. You cannot teach stupid people to do clever things
Post #69147 30th Apr 2011 9:40pm
leeds
Mike it might be well worth asking on the South African forums.
There again Kevin Mackman at Nene Overland might be worth a phone call as he is apparently a seasoned African traveller.
Also Barry at Flatdog is importing South African equipment.
Chris at Boab also knows a lot of the Australian gear.
Has Adrian at WVA made a double one?
Might be worth a few phone calls.
If I remember correctly one of the 'problems' with the Kaymar single wheel carrier wa the need to unfasten it and swing it out of the way before opening the rear door.
I am sure that I have seen a photo of a 'standard' type single swing away which had two wheels on. The arms/pivot had been seriously beefed up however.
Solving the problem another way, what about a single spare wheel, a spare tyre, tyre levers, compressors, plus some spare inner tubes? OK tubeless tyres are rougher on inside then tubed tyres but a tube in a tubeless tyre is only a temporary repair.
Question is what are the chances of bending two wheel rims?
Let us know what you find out
Brendan
Post #69161 1st May 2011 3:21am
Tazz
Re: Twin spare wheel carrier
Why can't you bonnet mount it?
Tazz
Post #69419 2nd May 2011 10:57pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
He won't be able to see much if it's on the bonnet Shocked
Post #69420 2nd May 2011 11:00pm
BigMike
Tazz
W hat sonic said. Also there is no room on the underside of the bonnet on a puma to strengthen the mount.
Post #69422 2nd May 2011 11:09pm
vinsell
Italy 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Look at this:
http://www.topgear.it/shop.php?act=zoom&am...a%20scorta
ciao Vinicio https://google.com/+VinicioSelleri
Post #69430 3rd May 2011 5:23am
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Maybe Sonic can answer this, as it has come up before.
Does his carrier not have the strength to cope with a second wheel mounted piggy back style just using longer bolts.
With it being connected only to the crossmember, the centre of gravity is as low as you can get, and it appears to be strong enough.... 2001 TD5 110 DCPU in Bonatti Grey
Post #69439 3rd May 2011 7:39am
BigMike
Cheers Both
Davie, I thought about that but at 600 quid it's more money than I want to spend to be honest.
Post #69442 3rd May 2011 8:28am
BigRuss
Designing a wheel carrier is easy getting it fabricated is the hard bit! Unless your good mates with Ray Thumbs Up Russell
Post #69446 3rd May 2011 8:41am
BigMike
Not sure that a twin wheel carrier is that straightforward due to the extra forces involved when offroad. The twin arms that kaymar does seem to be pretty robust, but I'm not sure how the italian one works from the pics and if its just that the bolts are longer. if thats the case, then i m not sure how it would fare with day after day or desert corrugation (for example). The new safari equip wheel carrier is a real solid thing, but I need to discuss with them the possibility of two wheels, and also a clamp for a roof tent ladder which I desperately want so I dont need to put a dirty ladder in the tent.
Post #69451 3rd May 2011 8:44am
Page 1 of 4 1234>
