Home > Td5 > oil leak
baldy
2006 Defender 90 Td5 HT Zambezi Silver
oil leak
my 2006 defender 32000 miles drops oil after any long distance drive not agreat amount but its anoying icant find the source engine oil seems to b the same not losing any on dipstick any ideas welcome
Post #69089 30th Apr 2011 11:10am
BigMike
put paper underneath and see where its coming from. possibles are diffs, transfer box, gearbox, axles etc.
Post #69090 30th Apr 2011 11:43am
baldy
thanks i will try that tomora as im of to llandudno its a good long run from wirral
Post #69122 30th Apr 2011 5:46pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Check not leaking from oil filter, may need to be tightened. Also Fuel pressure regulator on rear of engine drivers side, these can start to leak diesel, common on td5.
Steve. Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #69296 2nd May 2011 9:09am
ARMYBOB
United Kingdom 2001 Defender 110 Td5 CSW Java Black
stevie d, i had the same thought
my 2001 had what i thought was an oil leak but never lost any, turned out to be the fuel pressure regulator leaking, as the fuel ran down teh side of the engine it was catching all the crap with it and it looked like oil underneath, dip a finger in the drip and smell it, feel teh texture you can tell.
the regulator is right side of teh car towards teh bulk head, you need to lift the cover to get to it, easy enough to change just a bit fiddly
Post #69322 2nd May 2011 12:21pm
baldy
ill check them asap oil filter now thats a pain to fit
Post #69406 2nd May 2011 8:31pm
