Home > Td5 > oil leak |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
put paper underneath and see where its coming from. possibles are diffs, transfer box, gearbox, axles etc.
30th Apr 2011 11:43am |
baldy Member Since: 29 Apr 2011 Location: wirral Posts: 3 |
thanks i will try that tomora as im of to llandudno its a good long run from wirral
30th Apr 2011 5:46pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Check not leaking from oil filter, may need to be tightened. Also Fuel pressure regulator on rear of engine drivers side, these can start to leak diesel, common on td5.
Steve. Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
2nd May 2011 9:09am |
ARMYBOB Member Since: 16 May 2009 Location: north luffenham, rutland Posts: 81 |
stevie d, i had the same thought
my 2001 had what i thought was an oil leak but never lost any, turned out to be the fuel pressure regulator leaking, as the fuel ran down teh side of the engine it was catching all the crap with it and it looked like oil underneath, dip a finger in the drip and smell it, feel teh texture you can tell. the regulator is right side of teh car towards teh bulk head, you need to lift the cover to get to it, easy enough to change just a bit fiddly |
2nd May 2011 12:21pm |
ill check them asap oil filter now thats a pain to fit
2nd May 2011 8:31pm |
