Home > Td5 > More heat needed
Page 1 of 4 1234>
excossack
More heat needed
In my TD5 110, I have good air flow/speed from the blowers and currently only have 2 settings on the direction of air flow. Windscreen or foot wells and windscreen. The cable clamp slips on the cable cover on the mounting plate which is why I only have 2 settings.
What I don't have is huge amounts of heat. I get more heat out the top vent than the bottom vents.
I am sure before the bulkhead was done, the heat was a lot more. Last measure was around mid 50degc from top vents. Not sure if this the right amount of heat or not?
I did replace the coolant last year and also the thermostat (which I found to be faulty) and then reverted back to the old one.
I flushed the matrix out as well when I replaced the coolant.
From what I can tell I have full movement on the lever that controls heat output from the matrix/heater housing. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #689560 28th Feb 2018 11:35am
I'm going to be positive about the Puma.... I had the window open on the way in today..heater speed 1 and I was boiling Mr. Green
The td5's heater is woeful.
Post #689563 28th Feb 2018 11:42am
excossack
Thanks that helps.....
Can a Puma heater be fitted to a TD5? 1999 Defender TD5 110
Regards
John M0VAZ
Post #689565 28th Feb 2018 11:57am
Procta
get some of graftys vents Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #689573 28th Feb 2018 12:14pm
excossack
I have some - and they are ace. But need more heat! 1999 Defender TD5 110
Regards
John M0VAZ
Post #689575 28th Feb 2018 12:17pm
rallysteve
I have the issue that my new heater matrix is so efficient that it just cools the TD5 engine back down again in cool weather! 02' 110 TD5 Double Cab Rebuild Thread
Post #689576 28th Feb 2018 12:19pm
excossack
What matrix do you have? 1999 Defender TD5 110
Regards
John M0VAZ
Post #689578 28th Feb 2018 12:21pm
rallysteve
just a new OE one 02' 110 TD5 Double Cab Rebuild Thread
Post #689579 28th Feb 2018 12:24pm
excossack
Worth the effort? Did you swap because of lack of heat? 1999 Defender TD5 110
Regards
John M0VAZ
Post #689580 28th Feb 2018 12:25pm
rallysteve
I actually swapped it out because of a coolant leak from the end of my old matrix, however the new one (along with replacing the foam insulation within the heater box) is much more efficient that the old one (which wasnt visibly corroded or blocked that i know of). Trouble is you have to hold off turning the fan up until the engine has warmed up fully in cold weather or it cools the engine back down.
I did see an Alisport uprated heater matrix however.
Post #689581 28th Feb 2018 12:30pm
excossack
Cheers for the info Steve. I might have a look into the matrix side of things.
I don't have Alisport money. 1999 Defender TD5 110
Regards
John M0VAZ
Post #689583 28th Feb 2018 12:36pm
Part of the issue is the lower part of the dash is basically the whole of the piping before it gets to the piddly little vents.
Even a brand new matrix isn't great (have one on the V8 ) and they are a lot warmer running than the td5!
Maybe a diesel heater like Eberspacher?
Post #689615 28th Feb 2018 2:40pm
geobloke
Woeful? Poppycock... It is adequate when dressed correctly...
Besides, follow these simple rules for dress code and you'll make it through to Spring;
Post #689628 28th Feb 2018 3:20pm
geobloke
Unfortunately not.
Post #689630 28th Feb 2018 3:20pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Rad muff might work
Post #689631 28th Feb 2018 3:21pm
Page 1 of 4 1234>
