![]() | Home > Td5 > More heat needed |
Ditto to this. As soon as I slow down or stop it takes no time at all for the temperature gauge to fall back to the cold side of the range... |
Back in the dark ages of 200tdi defenders folks had good results from lagging the internal ducting to stop the heat from escaping the enormous bulkhead shaped plenum chamber. Might be worth looking in to. Apart from that Eberspacher is the way forward. I did see these, thought they might be worth a punt; https://www.ebay.co.uk/itm/5000w-Air-Diese...0505.m3226 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5922 ![]() ![]() ![]() |
I did wonder about those, but would rather have a UK seller than a Chinese one (for warranty etc) for the price though, not bad. I did read about a flap being open that can get cold air in from the airbox side but not dug much deeper TBH. Anyone got pics of the ducting or a diagram of the pipe work ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2205 ![]() ![]() ![]() |
Could fit the Allisport uprated heater matrix
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1878 ![]() ![]() |
quote: "could fit the Allisport uprated heater matrix"
Yep - just done that - see here: http://www.defender2.net/forum/post689662.html#689662 As that post on the other thread will show it's not something to be taken on lightly. For me at least it was a job with a really high ![]() I will say that it definitely does its job though - a significantly increased heat output - and I didn't notice any engine cooling even in the temperatures we have at the moment. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2123 ![]() ![]() ![]() |
May I humbly suggest a diesel powered cab heater .... this will solve your problems in one hit and have more benefits of heating the cab when parked up at night... just a thought !
![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 934 ![]() ![]() ![]() |
My td5 heater is normally fine, in fact very good, however I did notice the temperature gauge struggling whilst crawling to work in traffic early this morning in the colder temperatures/snow, my engine has no under bonnet pad, wonder if that helps things...
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 617 ![]() ![]() ![]() |
Made no difference to my old TD5... They help keep crud out of the radiator, but as the thermostat will be closed in low temperatures (or should be!) there will be no water flowing through the radiator anyway. |
Almost correct. But a insolated coverall helps too. ![]() ![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Fitted heated seats in mine. It's glorious. Do keep looking at a diesel heater in future, but it's a long way down the list!
I am planning on refurbing the seats and heater elements are going in.
Diesel heater has also been on my list. Does anyone know the correct position for the heater flap on the matrix housing? Do you move it as far is it goes (hear it hitting the insides) then adjust cable to get max movement? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7910 ![]() ![]() ![]() |
I have the same issue in the 200Tdi, just need more heat! My first V8 hybrid 90 was never short of heat, I'm sure it had a heater exchange from a Range Rover Classic, but can't quite remember. Would this improve cabin heat? Easy job to fit? James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
That's just what I did at the weekend. Made sure the flap is fully over to the 'heat' side (air from the duct is being directed to the matrix) and then adjusted the cable to correspond to that. Then check that, as you move the dash control, you get full range of movement of the lever on the heater box. You can see it working anyway - bonnet up; driver's window open, and you can see the lever on the box moving as you move the dash control up and down. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
voorfrank Member Since: 06 Feb 2017 Location: Schiedam Posts: 37 ![]() ![]() ![]() |
In my old Defender I replaced the low vents for these:
![]() Installed 2x left and 2x right. This was a big improvement. https://www.ebay.co.uk/itm/Pair-of-60-mm-A...1290678994 |
