Home > Technical > windows of the diffrent year defenders
Bert@E
Netherlands
are the front door windows of the diffrent year defenders the same?
Post #689078 26th Feb 2018 6:47pm
miker
Really early 90/110s had the series style doors I think, then production up until 2005 (ish) had the welded steel frames with aluminium skins that rust to Censored and corrode, the later doors were pressed steel frames with steel skins.
Post #689082 26th Feb 2018 6:54pm
zsd-puma
If they're wind up windows they're all the same I think. There are options for tinted or non-tinted glass but they're the same shape.
Post #689083 26th Feb 2018 6:54pm
miker
I saw front doors, I realise now my response is fairly useless!
Post #689084 26th Feb 2018 6:56pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Some were all alloy - with double sliding windows. They were fitted to military Defenders and also some 110's. They are brilliant as they don't rust. Grab some if you can!
 Euro-Leafing to infinity and beyond.....
Post #689093 26th Feb 2018 7:22pm
Grouse
90/110's never ever had Series sliding door windows. They had the their own specific aluminium sliding style. The 90/110 sliding door windows are exactly the same as the military ones. Both parts slide and the windows are angled so they can slide further forward.
The Series are single window sliding, the windows are horizontal join and they are steel and rot horribly.
Post #689101 26th Feb 2018 8:01pm
okami
United Kingdom 1993 Defender 110 200 Tdi SW Montpellier Red
There is also 5mm (earlier) and 4mm (later) glass to contend with.
Edited to correct the sizing...
Post #689113 26th Feb 2018 8:25pm
zsd-puma
No one said they had the 'same' doors or windows as a Series, just that they had "Series style doors"- 'in the style of' doesn't mean identical.
Post #689116 26th Feb 2018 8:27pm
Grouse
No they aren't all the same - the early wind up window doors - 1984/1985 - had the series lift up door latches, with fake galvanised door cappings held on by plastic plugs. The galvanised door cappings were then dropped in 1986 but the latches were still the lift up Series versions which were then dropped for the push button type the following year.
Post #689130 26th Feb 2018 9:07pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Being a real pedant here and afaik the production 90’s (except for military versions as mentioned) were never fittted with the sliding windows in the all aluminium frames. However the few pre pro Ninetys were fitted with the aluminium framed door tops with sliding windows.
Post #689131 26th Feb 2018 9:08pm
Grouse
Correct
Post #689132 26th Feb 2018 9:09pm
Slideywindows
Given my username, I will say nothing about slidey versus wind-up windows other than civilian One Tens had their slideys until June 1984.
Post #689144 26th Feb 2018 9:38pm
Brendlynch
Jersey 2005 Defender 110 Td5 XS CSW Cairns Blue
I have been offered a set of factory tinted windows from a Puma 110 for my 2005 110 TD5.
Any compatability problems with these?
Also what would a set be worth?
Post #689155 26th Feb 2018 10:14pm
zsd-puma
The original question was about the windows not the doors, Which I replied to. Did you even read the original post?
Post #689176 26th Feb 2018 11:45pm
Grouse
Yes, And the different window designs also need different doors - you would have missed that.
Post #689186 27th Feb 2018 4:32am
