Home > Technical > windows of the diffrent year defenders
Page 2 of 2 <12
zsd-puma
How about you just answer the original question grouse, rather than just come on here an be a rude pedant picking holes in everyone else comments? Rolling Eyes
Perhaps learn a few manners......
Post #689205 27th Feb 2018 8:23am
Grouse
Shocked blimey - have you tried anger management
Post #689217 27th Feb 2018 9:33am
zsd-puma
As I said perhaps learn a few manners.
Post #689221 27th Feb 2018 9:47am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
The answer is no they are not the same. Just the thickness as mentioned before. However you can make it fit Land Rover style. I have 2003 glass in 1984 doors. The only things you have to change are all the doors internalls. As the lifting system is different you also need to use the newer inside door plate or modify the old one. And as the newer glass is thicker you need the glass guiding thing also from the new glass.
But then if you chnage to the newer door inside panel door inside door opener doesn't fit so you might have to modify that. etc. Whistle
But you can do it.
Like I said 1984 doors with 2003 glass. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #689225 27th Feb 2018 9:54am
Page 2 of 2 <12
