Home > Technical > 8274/Bow 2 motor issue
Chedgy90
United Kingdom 1994 Defender 90 300 Tdi HT Rimini Red
Evening guys.
Ive just tried putting on a bow 2 motor on my 8274, and cant figure out what the issue is with it not working. Censored
it was running a standard motor fine, i managed to get maybe one drum rotation out of it before it stopped working.
The soleniod seems to be clicking away but nothing is happening.
maybe the soleniod isnt upto the job? I have no idea what type it is.
Any ideas?
Thanks
Post #688316 22nd Feb 2018 10:35pm
roel
First do a basic test if the motor is still OK
Disconnect all cables.
You have 2 connections near the output shaft.
Put a battery plus on one of them.
Connect the other to the connection on the other side off the motor.
Now you have one connector on the btm off the motor connect that to the negativ off the battery .
The motor should run now.
If not the motor is broken. If the motor runs now you have to look to the wires or solenoids.
Good luck Roel
2003 90 Td5 (2009-now)
Post #688389 23rd Feb 2018 11:48am
jst
as above, check motor works, ideally in situ then on a bench if it doesnt work in situ. make sure the motor is held firmly if bench testing.
you can also remove the manual freespool to remove any load on it then test.
connect earth jump lead to bottom of motor
F1 to battery +
connect F2 and A together. it will rotate one way
F2 to +ve
connect F1 to A it will rotate the other way
i would wire it direct with jump leads to a battery +ve and Earth cables. use 35mm2 cable to connect F1 and A.
it will arc off terminals if you just touch cables to them (assuming it works) so i would use flying leads to jump leads as you dont want to damage the threads.
You have got the earth strap on it i take it?
Did you remove the manual freespool gear when you fitted the motor? not a shaft alignment problem there? if you just pulled motor out and slid new one in without touching manual freespool then that could be the problem.
I have used and run 8274 based winches for last 15years with XP, Bow 1, 2,2.5 and 3s for comps and pretty much everything else. Post up your findings and we can go from there. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #688405 23rd Feb 2018 1:00pm
Chedgy90
Right so I popped down to Winch-It to get a new solenoid.
Got a 600a one now so that should handle the power.
He told me about how to test the motor. Ive done that. Motor is working fine.
Still not working even with the 600a solenoid Banging Head Banging Head Banging Head
Post #688432 23rd Feb 2018 3:19pm
roel
It must be a wiring problem then. Can you make a picture how it is now connected? Roel
Post #688478 23rd Feb 2018 7:26pm
jst
so its got an earth?
what was score on the freespool fitting?
is winch motor on or off the winch?
did you test it as suggested above or was that the same suggestion? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #688482 23rd Feb 2018 7:32pm
jst
original solenoids were clicking which suggested that they were working fine. its wired correctly at solenoid end? by taking off old motor A and either F1 or F2 werent in different locations? have you gone back to same physical locations or to actual A, F1, F2 etc? haev you checked that against wiring diagram for Albright? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #688486 23rd Feb 2018 7:50pm
jst
any joy with it? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #688975 26th Feb 2018 1:13pm
roel
If the soleniods are clicking it doesn't mean that they make good contact. I know from experience. Evil or Very Mad Roel
Post #689022 26th Feb 2018 4:23pm
jst
I concur but, the originals were clicking and hes changed them anyway so it would suggest they are ok.
until he does whats been suggested or posts up his findings its a bit of a waste of time trying to help anyway. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #689133 26th Feb 2018 10:10pm
roel
Yep, but not everybody is here daily. Laughing Roel
Post #689167 26th Feb 2018 11:44pm
jst
yep i get that, was just looking to help. we will see, time will tell. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #689254 27th Feb 2018 12:44pm
