Home > Puma (Tdci) > Greasing front propshaft
UtilityTruck
Is it actually possible to grease the front prop shaft on the puma without removing it?
I’ve done the rear prop, both ends, by modifying my gun nozzle but the front prop looks impossible- the yoke covers the nipple completely and the head of the nipples point into the yoke?? 2014 Keswick Utility 2.2
Post #685909 11th Feb 2018 9:55pm
Roy5695
I’ve managed to do mine several times. Either your nipple had snapped Big Cry or its been replaced with a different type. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #685917 11th Feb 2018 10:18pm
UtilityTruck
Both front prop nipples are the same, neither have snapped and I’ve had the truck since new so I don’t think there is much chance of them having been swapped.. 2014 Keswick Utility 2.2
Post #685924 11th Feb 2018 10:37pm
williamthedog
You should be able to grease the prop in place.
I've always done mine in place Thumbs Up
Post #685943 12th Feb 2018 6:04am
agentmulder
Kuwait
Nipple could have loosened, fasten it until you can either use it or you think you're going to shear it off.
That and a combo of letting off parking brake until its ideally positioned.. Solved the bowel problem, working on the consonants...
Post #685947 12th Feb 2018 7:18am
AJC
I had same issue with my TD5 front prop, manual grease gun end was too big to fit between the UJ's, I had to use a different gun with a slimmer end.
Original grease gun did every other grease nipple no problem.
Could hear the grease popping as it was pushed in Very Happy
Post #685951 12th Feb 2018 8:07am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
For the awkward "one" i use a chain saw grease pump on the ball valve.
Post #686008 12th Feb 2018 11:43am
UtilityTruck
Do you mean something like this?
https://www.clarkforest.com/shop/chainsaw/...rease-guns
I’ll have to take a pic of my prop because I can’t see how that would help- there is just zero room... 2014 Keswick Utility 2.2
Post #686019 12th Feb 2018 12:11pm
Lightningtweeds
Thats the one but if you jack up the car on the driver side it opens the yoke up.
Post #686028 12th Feb 2018 12:38pm
UtilityTruck
I’ll try jacking it and see if it opens up enough- many thanks. I was expecting to be able to do it with the truck on the ground. 2014 Keswick Utility 2.2
Post #686063 12th Feb 2018 2:06pm
jst
it depends on what grease nipple is on the UJ, they are not all the same, some are between spiders, some as in middle with angles head, some had the later with the angled head snapped off! just remove it axle end and grease whole things whilst manipulating the joints through full range of movements. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686075 12th Feb 2018 2:53pm
InternationalDBA
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I struggle with this job too with my grease gun if the propshaft is on the vehicle.
Post #687681 19th Feb 2018 7:58pm
pannawonica
Australia
As said jacking up one wheel and rotating for position works well! However with no threaded hole for a spline nipple too be fixed prop occasionally has too be removed! Special tool works there! Thumbs Up
Post #687782 20th Feb 2018 11:52am
UtilityTruck
So... I jacked up the front so I could spin the front prop- the picture above shows what I found. Both ends are essentially the same- rotating the prop doesn’t really help- the nipple is shielded by the yoke.
Is a right-angle, extremely low profile grease gun extension a thing? 2014 Keswick Utility 2.2
Post #688495 23rd Feb 2018 7:23pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
That’s a handy place to put it!
Post #688744 25th Feb 2018 9:48am
