Home > Puma (Tdci) > Greasing front propshaft
Page 2 of 2 <12
ARC99
That's what I found when I tried the first time to do mine, I bought a flexible end for the grease gun . Don't make old people mad.
Richard
Post #688746 25th Feb 2018 10:56am
Vitesse
This is quite interesting.. Have been following this range of tutorials recently. Thumbs Up
&t=69s 2015 90 XS Santorini Black
Post #689260 27th Feb 2018 1:38pm
Merlin
Doesn't anyone fit grease nipple protectors anymore? Keeps the muck out.
Merlin
Post #689316 27th Feb 2018 4:09pm
It would appear not.
Post #689356 27th Feb 2018 7:34pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
The only 'grease nipples' with protectors I know are the brake bleeding plugs. Twisted Evil Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #689407 27th Feb 2018 9:39pm
Never seen any on a propshaft - wouldn't they just fly off any fast moving parts?
Post #689524 28th Feb 2018 10:51am
Merlin
I've always fitted grease nipple covers and haven't lost one yet off of a UJ or prop shaft. I bought them off eBay, search for RUBBER GREASE NIPPLE COVERS.
Post #689584 28th Feb 2018 2:00pm
nidge n
Guys, what is the recommended frequency for greasing the props. Thanks
Post #689726 28th Feb 2018 8:54pm
dorsetsmith
10,000km or 6 mouth
Post #689738 28th Feb 2018 9:13pm
Grouse
@UtilityTruck
Did you jack up from under the axle?
If you jack it up from under the chassis, this then let's the axles hang down - you still need the tyres off the ground, and this gives max axle travel / drop which widens the gap at the side of the universal joint - you should then be able to get the grease gun in then.
Sometimes you can get into the joint from the side at around 2 to 3 o'clock if that makes sense.
A decent trolley jack and a block of wood under the chassis rail helps
Post #689861 1st Mar 2018 7:52am
UtilityTruck
Grouse - I must admit I jacked under the axle. Now you mention it, it’s obvious letting the axle droop will help access. I’ve got a needle adaptor for my grease gun on order- I shall report back if this gives sufficient access to do the front prop. If not I’ll have to stop putting off buying a new trolley jack. Oh well! 2014 Keswick Utility 2.2
Post #689862 1st Mar 2018 8:05am
Grouse
Thumbs Up
Post #689883 1st Mar 2018 10:00am
GrouseII
United Kingdom 2008 Defender 90 Puma 2.4 HT Coniston Green
Oops, just happened to see your post.
I have been posting signing as Grouse rather than my official GrouseII username.
I doff my cap to you sir and apologise. I will sign as GrouseII from now on to avoid miss representation Wink
GrouseII
Post #689941 1st Mar 2018 1:35pm
Grouse
No problem Thumbs Up
Post #689982 1st Mar 2018 3:52pm
Page 2 of 2 <12
