Home > Puma (Tdci) > PUMA BONNET SECURITY
noworries4x4
Right then i got asked loads of questions about the steel cable holding my new bonnet down recently and i promissed every one photos at the wwekend, well actually i have done better than that because working in the crane industry it was easy for me to get something made up which was going to be hard for you all the replicate so i took mine off trolled down to Homebase to see what i could find that would be suitable and lo and behold look what i found for the grand total of £6.99 Bargain
The next 2 pictures show under the bonnet reinforcing and the front lifting eye
Right then i bet you can all guess and now see where this is going !! Laughing
Feed the lock wire between the bonnet reinforcing and the bonnet itself it just needs a little push up with your thumbs to make the gap big enough.
Feed the lock wire through all three panel gaps and go round again just to loose the length then wrap round to make it tidy.
Bring the cable end down through the engine lifting point
Now for the fun bit shut the bonnet down to the lock but not closed lift up a little with your arms right under and close the lock the bonnet should only open 12" to 18" max adjust cable to suit
Job done close bonnet sleep easy your bonnet will be there in the morning and the next and the next.
It is not meggga hi tech but it is not expected the scum will force your bonnet find it won't open enough to clear the hinges and give up they wont be tooled up to be cutting steel wire cables they came to nick a bonnet.
[/b] If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #68375 23rd Apr 2011 6:10pm
BigRuss
Thumbs Up Cheers bud Russell
2011MY 110 XS USW Black
Post #68378 23rd Apr 2011 6:21pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Excellent post! Cheers for that. Thumbs Up Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #68407 23rd Apr 2011 9:49pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Thanks for that! I was thinking about something similar, we have a thin cable w/ barrel lock for laptop/IT kit security - I was considering using that until I read this post.
Post #68410 23rd Apr 2011 9:57pm
Kez
Isle Of Man
Great idea - I also just changed the standard six hinge screws / bolts for a set of stainless steel security Torx screws - total cost less then £5 - you can get them here http://www.a2stainless.co.uk/Land-Rover-De..._ADDB.aspx
Post #68411 23rd Apr 2011 10:00pm
Grockle
nice one Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #68462 24th Apr 2011 1:13pm
mega
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi I did the very same thing on my 110 usw they cut the cable , I lost the bonnet , all 4 doors and a seat in one night. the insurance claim is 13K.
Post #68469 24th Apr 2011 2:07pm
noworries4x4
You cant say you did'nt try it's all we can do is slow them down a bit, must have been parked somewhere quiet that lot did not take 10mins
Most will come across someting like the cable and give up and go find soneting easier.
I went to the commercial vehicle show a couple of weeks ago and there was a company there locks4vans that had some nice slam locks that i will investigate further when i get my new Defender in Oct If everything is under control you are not going fast enough.
No Worries 4X4
Post #68472 24th Apr 2011 2:52pm
eutek
Re. the security screws - which would your average scrote most likely not be prepared to deal with - torx, hex or pozi screws?
Post #68573 25th Apr 2011 11:26am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Just fill all the door hinge bolt heads with clear silicon sealant. Slows them down alot as you have to dig the silicon out before undoing.
Secondary power supply to alarm, if fitted, upsets them also. Whistle
Post #68579 25th Apr 2011 2:16pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
You can get these, http://www.securitysafetyproducts.co.uk/se...ew-group=5. I seriously doubt they would have the tool to remove them Smile
Jack
Post #68582 25th Apr 2011 2:36pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i know most people will know but incase there is someone who dosen't, just remember that the bonnet can be removed from the car by lifting it to near vertical and just lifting it out of the hindges, can be done in 2 seconds with 2 people, no need to unscrew a thing.
i'm thinking about knocking up a guard for the underside of the catch,????????
not even looked yet, but thinking.
Post #68586 25th Apr 2011 3:00pm
WelshGas
Just thinking Idea Idea
Something that would stop the bonnet going vertical would allow normal use but prevent it's removal. Some form of stop on the hinge using a security bolt Question Question Idea Idea
Post #68587 25th Apr 2011 3:07pm
Kez
Isle Of Man
Shocked I didn't know that was still the case, know it was on old series ones, am horrified its so easy!
Might be an idea to edit that last info before every scumbag and his wife picks up on it Shocked
Post #68591 25th Apr 2011 3:52pm
T1G UP
common knowledge my friend from 90's to pumas!
if someone could design a set of hinges that can only move up to 45 deg angle that would stop them from being lifted off
Post #68593 25th Apr 2011 4:35pm
