Home > Maintenance & Modifications > Dampers: OME vs. Koni?
I've run OME stuff on various defenders for years, always been happy with it.
Current 110 has factory HD springs (happy with them), and OME HD gas front dampers (I forget the part number now).
a year or so back, one of the rear OME's (N44) died, lost all pressure. So I just stuck in a pair of standard LR oil filled jobbies. Did the job but the handling isn't as nice as it used to be (hardly surprising really with gas up front and oil in the back)
Anyway, I'm doing a mini overhaul soon, so amassing parts ready to fit. I was going to just get another pair of N44's for the rear, but I hear/read good things about Koni Heavy track "raid" dampers, part # 90-5375SP1 which seems to do 90/110/130 rears in HD flavour (although most dampers seem to be listed like this... how can a HD 90 one be suitable for a 130? anyway....)
prices vary from £93 each at Paddocks up to £240 from a "specialist" suspension company Rolling Eyes
But question is; has anyone used them? any good? any bad?
cheers
Post #684296 5th Feb 2018 2:46pm
rustandoil
Yeah Ive been using the Koni special track on my 110 for a while, still working well despite the shroud cover rotting away and falling off!
I might be able to look up how long they've been on there Confused
Post #684298 5th Feb 2018 2:54pm
I've had them on two different vehicles - a Discovery 1 that was loaded for overlanding and a predominantly road-going 110 - and was very pleased with them. They are adjustable, in that you can set the stiffness to one of three settings at time of installation, which allows you to tune them to your use to a degree.
It's worth noting that there are two variants - Heavy Track and Raid, with the latter being much more expensive and which probably explains the price differences that you noted. The Raid version is really for more serious competition use and overkill for a general purpose truck.
http://www.koni.com/en-US/Cars/Products/OffRoad/ Darren
Post #684303 5th Feb 2018 3:36pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
I have the Koni heavy tracks on all four corners of my 110. Really like them, I have standard springs on the front and HD on the rear. They stood up to 6 weeks in Morocco last year on some very harsh terrain and performed faultlessly.
Post #684316 5th Feb 2018 4:57pm
familymad
OMU are better quality 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #684339 5th Feb 2018 6:15pm
Is that opinion or based on something in particular? Darren
Post #684353 5th Feb 2018 7:20pm
jst
I tried konis a while back, they were ok but the ome quality line seemed better at the time so I switched to them and stuck with ome. I have them on my 110 hd std length around, also have +40 iirc on soft top around, have +2" on truck cab, and Trayback had them on rear n44 equivalent before going to Plus 5 ome. Youngest set are 3years old, oldest set 9 years old. All going strong used across range from on road, driver trg, drive round days and competing. Just looking to get some more really! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #684359 5th Feb 2018 7:46pm
williamthedog
Had konis on mine for about 4 years, no issues with them at all. A good set up for my 90 Thumbs Up
Post #684363 5th Feb 2018 7:55pm
familymad
Had OME on our 110 TD5. Far better ride and plusher. Lasted for years and no rotting out. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #684395 5th Feb 2018 8:57pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have had my Konis on my 90 for 7 years
They have had a lot of abuse from rough tracks in the Pyrenees/Alps to bad corrugations in Iceland - 90 fully loaded
Also well behaved on tarmac
I would recommend them
Post #684502 6th Feb 2018 12:39pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Koni HT-Raid´s on my 90 fitted by the first owner when the car was new in 2012. Very happy with them, and even more so with Koni´s after sales service. When a front unit lost pressure about two years ago, Koni replaced the front pair for the price of one unit. Thumbs Up
Apparently the chunky HT-R´s are basically an adapted model from their truck range. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #684524 6th Feb 2018 3:15pm
mick
Koni on mine with standard springs always loaded, gives a real nice ride on road and tracks
Post #684527 6th Feb 2018 3:42pm
roel
I had koni's on my CT 300 tdi. Empty weight almost 2700 kg. I run them for about 80.000 M and they are still under the CT D1. I love them and when my 90 dampers give up, koni will replace them. Roel
2003 90 Td5 (2009-now)
Post #684549 6th Feb 2018 4:47pm
Excellent, thanks all!
Koni's it is then I reckon.
Post #684614 6th Feb 2018 8:07pm
mick
I found these cheapest at the time https://www.larkspeed.com and there was something on there about a good guarantee
https://www.larkspeed.com/shopper/i/112L82401181SPX Free life time guarantee
Post #684656 6th Feb 2018 9:58pm
