Home > Maintenance & Modifications > Anderson Plug Location
Screbble
I've 'inherited' some SB175 Anderson Plugs (yellow) from Mobile Centre. One is made up already with the 35mm2 cable and lugs. It also has the cable shroud and protective cover.
I intend to install the above via a 300A marine isolater (mounted inside the vehicle!).
I'll only be using it for a set of jump leads and a C-Tek (overkill for the latter I know - but convenient).
As I don't do anything other than the odd green lane, and certainly don't go wading, I was thinking of mounting it in front of the rear near side wheel under the arch. I have a substantial YRM replacement brace fitted between the body and side panel and it'd provide a decent mounting point. I could keep it out of the way of harm but easy enough to reach.
However as I haven't started anything yet I can mount it anywhere within reason.
Where have you mounted yours? Pics please.
Will
Post #684062 4th Feb 2018 5:14pm
bankz5152
Mines on the seatbox in the pasenger footwell. Close to battery and easy access
Post #684063 4th Feb 2018 5:33pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Mines on the front of the passenger seat box as well :
 2010 Defender 110 Station Wagon, Santorini Black.
Post #684064 4th Feb 2018 5:36pm
VeeTee
Netherlands
Re: Anderson Plug Location
That is just the no 1 place I would NOT use...
This place will get the full load of road spray, and your know there are more days raining than dry weather where you live... Laughing
I think, as others have suggested, the front of the seatbox is a good place, dry, in reach and short cable run to the battery. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #684066 4th Feb 2018 5:45pm
Screbble
Good god man - it doesn't rain in Lancashire! Rolling with laughter
And of course I don't intend on driving beyond the county boundary....
Yes very good point.
Thanks to others for their input.
I've seen a bracket made for Anderson connectors that would allow be to mount it 'through' the seat box with only the end poking out in the passenger footwell to annoy SWMBO.
I've seen a few mounted underneath the grill/bumper similar to our roadside recovery vehicles but I think that could be vulnerable and the cable run wouldn't be as convenient as the above suggestion.
Any other ideas? Keep the coming?
Post #684094 4th Feb 2018 6:30pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I'm sure I saw one on here where someone had put one in a GMB Fender Locker. That looked quite smart and accessible. Not the shortest cable run though. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #684096 4th Feb 2018 6:34pm
Screbble
Yes I've seen the GMB Fender Locker installation somewhere - very good. Thumbs Up
Prompted by your post, I seem to recall a thread about a recessed panel on the side of the seat base - facing the door.
That might be an option for me I think.
Can anyone recall the thread/link?
Post #684132 4th Feb 2018 7:47pm
zsd-puma
I put mine on top of the front bumper below the grille. It's connected to the back of the winch.
Post #684149 4th Feb 2018 8:44pm
VeeTee
Netherlands
This one?
http://www.defender2.net/forum/topic58801.html Cheers, Vincent
MySite
Post #684153 4th Feb 2018 8:50pm
Screbble
That's the one Vincent Thumbs Up
Thanks.
Post #684196 4th Feb 2018 10:16pm
DAZ110
Could put it here?:
Post #684198 4th Feb 2018 10:22pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
I fitted on to my old 90 like this
Stupid location, as I had to have the door open to use it
Front of passenger seat box is the place Thumbs Up My confidence has been writing cheques that my abilities can't cash for years.
Post #684232 5th Feb 2018 1:18am
Screbble
Thanks for the inspiration and ideas Thumbs Up
Phase 1 now completed, with further input from SWMBO.
I connected it up without an isolator to check that it all worked, and that the plug on the jump leads mated fully with the in-car plug (as we wouldn't want the high-quality carpet preventing the plugs mating properly Rolling with laughter ).
Phase 2 will be to fit the isolator in some form of recessed housing on either the side or front of the passenger seat box. The FCX offering seems like the most likely proposal at the moment.
And yes.....the door does close with the connections made.......although in practice that probably isn't necessary. Neutral
Thanks again guys Thumbs Up
Post #685762 11th Feb 2018 2:12pm
Screbble
Well I've come round to the fact that due to a number of family and work commitments, these days it takes about two weeks to do what is essentially a two hour job Rolling with laughter
So it's all finished now. The plans evolved as I took on board feedback on and off the forum (thanks guys) and I'm pretty happy with the end result.
Post #688764 25th Feb 2018 12:57pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Looks really good, I'll probably copy your idea if I ever get around to it... Like you a 2 hour job I normally allow 2 months for as I only get 10 mins at a time Laughing Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #688771 25th Feb 2018 1:31pm
