![]() | Home > Maintenance & Modifications > Anderson Plug Location |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
Mines on the seatbox in the pasenger footwell. Close to battery and easy access
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Mines on the front of the passenger seat box as well :
![]() Click image to enlarge 2010 Defender 110 Station Wagon, Santorini Black. |
That is just the no 1 place I would NOT use... This place will get the full load of road spray, and your know there are more days raining than dry weather where you live... ![]() I think, as others have suggested, the front of the seatbox is a good place, dry, in reach and short cable run to the battery. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2186 ![]() ![]() ![]() |
Good god man - it doesn't rain in Lancashire!
![]() And of course I don't intend on driving beyond the county boundary.... Yes very good point. Thanks to others for their input. I've seen a bracket made for Anderson connectors that would allow be to mount it 'through' the seat box with only the end poking out in the passenger footwell to annoy SWMBO. I've seen a few mounted underneath the grill/bumper similar to our roadside recovery vehicles but I think that could be vulnerable and the cable run wouldn't be as convenient as the above suggestion. Any other ideas? Keep the coming? |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 ![]() ![]() ![]() |
I'm sure I saw one on here where someone had put one in a GMB Fender Locker. That looked quite smart and accessible. Not the shortest cable run though. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
Yes I've seen the GMB Fender Locker installation somewhere - very good.
![]() Prompted by your post, I seem to recall a thread about a recessed panel on the side of the seat base - facing the door. That might be an option for me I think. Can anyone recall the thread/link? |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I put mine on top of the front bumper below the grille. It's connected to the back of the winch.
This one? http://www.defender2.net/forum/topic58801.html Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
That's the one Vincent
![]() Thanks. |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
Could put it here?:
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
I fitted on to my old 90 like this
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Stupid location, as I had to have the door open to use it Front of passenger seat box is the place ![]() |
Thanks for the inspiration and ideas
![]() Phase 1 now completed, with further input from SWMBO. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I connected it up without an isolator to check that it all worked, and that the plug on the jump leads mated fully with the in-car plug (as we wouldn't want the high-quality carpet preventing the plugs mating properly ![]() Phase 2 will be to fit the isolator in some form of recessed housing on either the side or front of the passenger seat box. The FCX offering seems like the most likely proposal at the moment. And yes.....the door does close with the connections made.......although in practice that probably isn't necessary. ![]() Thanks again guys ![]() |
Well I've come round to the fact that due to a number of family and work commitments, these days it takes about two weeks to do what is essentially a two hour job
![]() So it's all finished now. The plans evolved as I took on board feedback on and off the forum (thanks guys) and I'm pretty happy with the end result. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Looks really good, I'll probably copy your idea if I ever get around to it... Like you a 2 hour job I normally allow 2 months for as I only get 10 mins at a time
![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
