Home > Puma (Tdci) > Central Lockkng. |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3376 |
Happens all the time! It's usually the actuator unit on the door.
You can get them for around 40quid, google 'defender central locking actuator' Simple enough job to swap out. |
1st Feb 2018 2:58pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 752 |
Mine stops working in the cold weather.... I have in the past taken the door card of and squirted a bit if WD40 around the mechanism and that's freed it off
1st Feb 2018 3:25pm |
It will be the wires from the b post to the door inside the rubber sleeve that have broken. Very common and easy to fix with a bit of good quality wire and a soldering iron.
The wife's 64 Reg has already had one rear door do this Ray My build thread http://www.defender2.net/forum/topic17615.html |
1st Feb 2018 3:51pm |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
As Mk1 says... wires inside the rubber conduit snap.
1st Feb 2018 4:28pm |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
wire inside the plastic sleeve. be prepared, the other side is comming soon. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
1st Feb 2018 5:54pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
99% chance of it being the wires. As diduan said, get ready for all the others to go. Try and get a roll of good quality cable(with a high number of conductors that can still be flexible in low temperatures) and do all the central locking wires and electric windows(if you have them) in all the doors. The cable size/quality JLR use is abyssmal(their procurement must just go out to buy the cheapest they can get hold of!!).
Each time you open and close the doors it creates wear on the cables which eventually causes the conductors to break. Its a pain in the ass to do, but if you do it with cable that should have been used in the first place you won't need to do it again. |
2nd Feb 2018 9:01am |
Check the wires for continuity, if they're bad chop through them and replace with some new wire. If the wires are good it'll be the actuator in the door, but it's normally the wires.
Don't bother buying a new door harness from Land Rover, it's about £70 for a couple of wires with a rubber boot in the middle and a connector on either end, it'll fail just like the original in next to no time!
Don't try doing it in situ, take the door card off and remove the harness, there is a plug just inside the B pilar you can un plug it there. It'll take 5 min to remove the door card, or an extra 20 min of swearing trying to fix the wire in situ. You'll probably tear the foam water shedder behind the door card when you try to peal it off, so buy a new one, they're only about £8 from Land Rover. |
2nd Feb 2018 2:27pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1835 |
My money is on the wires from the B pillar too. Had mine fail twice. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
2nd Feb 2018 4:33pm |
