Home > My Defender > Newbie with a TD5
CrazyK
United Kingdom 2002 Defender 90 Td5 CSW Cairns Blue
Newbie with a TD5
Hi Everyone,
Been lurking on the forums for a while now,
Thought it was about time I introduced myself and post some pics of my 2002 Td5 90.
Kieron
Post #682899 30th Jan 2018 1:59pm
miker
Looks very tidy! Nice colour too
Post #682906 30th Jan 2018 2:20pm
CrazyK
Thanks ...
I bought it about 6 months ago it’s pretty solid fir a defender,
If only I can get it to run as well as it looks!!
Kieron
Post #682910 30th Jan 2018 2:43pm
bankz5152
Looks good!
Whats up with it?
Post #682914 30th Jan 2018 3:07pm
miker
Ahh that's always a frustration, what's not right with it?
Post #682915 30th Jan 2018 3:07pm
dorsetsmith
If only I can get it to run as well as it looks ?
engine running rough ?
Post #682917 30th Jan 2018 3:20pm
rustandoil
Whats up with it? ....you're in the right place for help Thumbs Up
Post #682918 30th Jan 2018 3:42pm
CrazyK
yeah its not running right at the moment.
all of the problems seem to be related to the fuel system.
fixing one problem only identifies a new one Big Cry
Joys of TD5 ownership!
it broke down a few months back, It would restart (Eventually) and travel about a mile before dying again
Fuel pump making a bit of a racket - so suspected it to be the issue.
New pump and filter - No Change, Eventually tracked it down to a blocked Air bleed valve on the filter head - Cleaned and refitted.
Was running pretty well for a few weeks then it started having similar issues, at motorway speeds it would start to loose power then conk out and coast to a stop, again it would restart after a running the purge cycle (depressing the throttle 5 times) and cranking for a while, plenty of white smoke and it would cough and splutter into life. I booked it in to my local independent who diagnosed a bad MAF (Replaced) and MAP (Cleaned) sensors. Ran OK for a day or two the issue reappeared.
I removed the air return valve completely and went for a test drive, again at motorway speeds it started to loose power and slow down but no misfire lifting of the throttle and reapply it would start to pull again (engine kept running) for maybe 30 seconds then repeat. (possibly overboosting or a slow vacuum leak) Also when driving around town at boost it seems there is a slight delay of maybe a second or 2 between lifting off the throttle and the engine speed decreasing, the higher the RPM the more noticeable the delay.
Trying to get it back into the garage but as always they are unable to replicate the issue.
Kieron
Post #682921 30th Jan 2018 3:50pm
CrazyK
Thanks for the warm welcome.... owning a Defender is a love/hate relationship so good help and advice is always greatly appreciated!!
Kieron
Post #682922 30th Jan 2018 3:52pm
razz
2001 Defender 90 Td5 PU Caledonian Blue
hello , awesome colour indeed
Post #682923 30th Jan 2018 3:52pm
CrazyK
Very Nice Razz!!!
I really like the pickup!!!
Post #682924 30th Jan 2018 3:53pm
mikeh501
are those symptoms related to oil in the ecu wiring harness? could be wrong.
Post #682969 30th Jan 2018 6:56pm
CrazyK
I checked the red eco plug and no oil in the ECU plug and the previous owner changed the injector harness
but I will check again
Post #682974 30th Jan 2018 7:03pm
Procta
might be a punt, but change where you fill up from. just in case its the fuel you are using is causing some trouble Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #682979 30th Jan 2018 7:08pm
CrazyK
not really thought about fuel quality but I don't fill up from the same garage each time, I normally use 2 or 3 locally (BP, Shell and Sainsburys) so probably unlikely that all the would have dodgy fuel.
but thanks for the tips... will try anything at the moment to get it running right!!!
Post #682980 30th Jan 2018 7:10pm
