Home > Technical > Are front and rear wheel bearings the same?
Bluest
2007 Puma 110, are the wheel bearings and associated parts identical front and rear? 2007 110 TDCi Station Wagon XS
Post #681891 26th Jan 2018 4:25pm
dorsetsmith
YES
front and rear wheel bearing stc4382 two pre side
hub seal FTC4785
stack nut RFD 100000
Post #681897 26th Jan 2018 4:43pm
jst
Yes they are Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #681899 26th Jan 2018 4:45pm
Bluest
Thanks both! 2007 110 TDCi Station Wagon XS
Post #681905 26th Jan 2018 5:02pm
Procta
https://www.ebay.co.uk/itm/Land-Rover-Disc...SwENhZdxQB
these are the boys to go for Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #681922 26th Jan 2018 5:45pm
williamthedog
Yes agree with above use timken bearings if you want them to last.
Post #681962 26th Jan 2018 8:07pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Just out of interest, is this a roadside repair? I ask because I have seen advice to carry a spare bearing set when off road travelling but my Haynes manual Rolling Eyes suggests that a press or workshop vice may be needed. 2010 Defender 110 Station Wagon, Santorini Black.
Post #682049 27th Jan 2018 1:03pm
Bluest
It's for a spare kit in case it goes in Morocco. Whether I can do it without a press, I don't know. 2007 110 TDCi Station Wagon XS
Post #682051 27th Jan 2018 1:14pm
You do not need a press or vice and it can be done easily at the roadside provided that you have the right tools.
Post #682056 27th Jan 2018 1:32pm
sako243
The right tools consist of:
- 19mm socket to undo drive flange bolts
- something to remove the circlip
- flat screwdriver to knock back lock tab
- hammer
- 52mm socket
- soft bar for removing and reseating bearing races
- grease
All you really need. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #682068 27th Jan 2018 2:39pm
ChrisCM
Thanks for the info, a few more things for the spares box! 2010 Defender 110 Station Wagon, Santorini Black.
Post #682096 27th Jan 2018 5:09pm
sako243
All assuming you use the double nut method not the single stake nut method. Torque can be done by feel pretty easily. Ed
Post #682097 27th Jan 2018 5:12pm
Bluest
What’s that then? 2007 110 TDCi Station Wagon XS
Post #682110 27th Jan 2018 5:39pm
sako243
Referring to double nut vs single? Older models have two nuts with washer that's peened over to lock the two nuts in place.
Setting the torque, do it up tight (one grunt) until you feel resistance when spinning the wheel and then back off the first but so that the hub spins freely again. The lock tab and do up second nut tight against the first.
I find it easiest to loosely do up the second but first before bending the lock tab over the first. Then you can tighten the second and lock it in place. Ed
Post #682114 27th Jan 2018 5:43pm
Bluest
Thanks What’s the process on a standard Puma? 2007 110 TDCi Station Wagon XS
Post #682116 27th Jan 2018 5:45pm
