Home > Technical > Fitting Jate rings to front of Defender 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
What is your intended purpose for having them? $W33T $0U7H3RN $UG4R
17th Jan 2018 5:15pm |
the pre drilled chassis holes are relatively close to the front (just behind the bumper) for recovery
see below http://www.defender2.net/forum/topic11307-15.html |
17th Jan 2018 5:18pm |
Scamperbid Member Since: 19 Nov 2017 Location: Kent Posts: 34 |
Primary purpose is for recovery during light green laning/off roading
17th Jan 2018 5:38pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Definately in front of all the steering gear. The rear hole is for the steering box and panhard rod mount on LHD you would risk damage to the steering damper in this location 2002 90 Td5 Station Wagon
17th Jan 2018 5:40pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
good luck using them when your up to your sills in mud
17th Jan 2018 6:01pm |
Better off with a HD bumper imo, Jake rings have their issues. $W33T $0U7H3RN $UG4R
17th Jan 2018 6:03pm |
For light green laning and off roading then a bumper change might be a bit much. You can get those recovery eyes that bolt through the bumper bolts and bumper. Very neat and easy to access
This type of thing 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
17th Jan 2018 8:57pm |
There are plenty of options, depends on how much they're likely to be used really 2002 90 Td5 Station Wagon
17th Jan 2018 8:58pm |
on the front Jate rings are a straight swap for the factory towing eyes. Looks like your factory towing eyes are missing, but the holes for them are the forward ones in your photo.
18th Jan 2018 6:46pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
The holes you need should be sleeved on the inside for extra strength and quite near the front!
Click image to enlarge You can just about see them here! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
18th Jan 2018 9:48pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 762 |
Personally I have never been a fan of Jate rings and removed them from my ex-MOD 90 straight away.
As already stated, they are mounted quite low and to attach a bridle (shares the load between both chassis legs) you will almost certainly be reaching around in the gloop. Alternatively you could mount the bridle before you venture off the tarmac and leave it ready & waiting. As for myself I prefer recovery points at bumper height. ONE LIFE, GET IT! |
19th Jan 2018 8:06am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
^^ I love the retro look of the front of your Defender
Agree with you absolutely about the JATE rings, they're horrible things. The old-style D-rings such as you have are vastly superior in every respect and look better too, in my opinion. |
19th Jan 2018 9:11am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 916 |
Your not always bogged to sills and scraping around in the muck to find the rings. If the front is that far bogged is it sensible to continue pulling forwards, Depends on the situation.
I'll accept the JATE isn't a designed out of the box recovery point it has proven to do a good job at it. A lot of 'Lack of forward progress' is caused by cross axle or just purely no traction not always mud up to the door handles. They are fairly discreet too and work for those with A bar or other mountings in the way. |
19th Jan 2018 10:01am |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 |
As above jate rings have there issues, I had them on the rear a few years ago and after a few recoveries my chassis was a mess. Recovery eyes or HD bumper with shackles is the way to go
My set up Click image to enlarge 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
19th Jan 2018 8:17pm |
