Home > Technical > Fitting Jate rings to front of Defender 90
Scamperbid
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Would appreciate guidance on where to fit Jate rings to the front of a 57 plate PUMA Defender. The attached photo appears to show two options, one set of pre drilled chassis holes are relatively close to the front (just behind the bumper) and the second set further back in what looks like a purpose built housing? Thanks
Post #679316 17th Jan 2018 5:12pm
What is your intended purpose for having them? Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #679320 17th Jan 2018 5:15pm
dorsetsmith
the pre drilled chassis holes are relatively close to the front (just behind the bumper) for recovery
see below
http://www.defender2.net/forum/topic11307-15.html
Post #679323 17th Jan 2018 5:18pm
Scamperbid
Primary purpose is for recovery during light green laning/off roading
Post #679330 17th Jan 2018 5:38pm
grafty99
Definately in front of all the steering gear. The rear hole is for the steering box and panhard rod mount on LHD you would risk damage to the steering damper in this location Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #679332 17th Jan 2018 5:40pm
mikeh501
good luck using them when your up to your sills in mud Mr. Green
Post #679338 17th Jan 2018 6:01pm
Better off with a HD bumper imo, Jake rings have their issues. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #679341 17th Jan 2018 6:03pm
grafty99
For light green laning and off roading then a bumper change might be a bit much. You can get those recovery eyes that bolt through the bumper bolts and bumper. Very neat and easy to access Thumbs Up
This type of thing Thumbs Up
1990 Vogue SE
Post #679434 17th Jan 2018 8:57pm
grafty99
There are plenty of options, depends on how much they're likely to be used really Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #679435 17th Jan 2018 8:58pm
zsd-puma
on the front Jate rings are a straight swap for the factory towing eyes. Looks like your factory towing eyes are missing, but the holes for them are the forward ones in your photo.
Post #679692 18th Jan 2018 6:46pm
Roy5695
The holes you need should be sleeved on the inside for extra strength and quite near the front!
You can just about see them here! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #679758 18th Jan 2018 9:48pm
Litch
Personally I have never been a fan of Jate rings and removed them from my ex-MOD 90 straight away.
As already stated, they are mounted quite low and to attach a bridle (shares the load between both chassis legs) you will almost certainly be reaching around in the gloop. Alternatively you could mount the bridle before you venture off the tarmac and leave it ready & waiting.
As for myself I prefer recovery points at bumper height.
 ONE LIFE, GET IT!
Post #679821 19th Jan 2018 8:06am
^^ I love the retro look of the front of your Defender Thumbs Up
Agree with you absolutely about the JATE rings, they're horrible things. The old-style D-rings such as you have are vastly superior in every respect and look better too, in my opinion.
Post #679837 19th Jan 2018 9:11am
Devon-Rover
Your not always bogged to sills and scraping around in the muck to find the rings. If the front is that far bogged is it sensible to continue pulling forwards, Depends on the situation.
I'll accept the JATE isn't a designed out of the box recovery point it has proven to do a good job at it. A lot of 'Lack of forward progress' is caused by cross axle or just purely no traction not always mud up to the door handles.
They are fairly discreet too and work for those with A bar or other mountings in the way.
Post #679856 19th Jan 2018 10:01am
StephenO
As above jate rings have there issues, I had them on the rear a few years ago and after a few recoveries my chassis was a mess. Recovery eyes or HD bumper with shackles is the way to go Thumbs Up
My set up
 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #680030 19th Jan 2018 8:17pm
