Home > Td5 > Strange cruise control behaviour
Page 2 of 4 <1234>
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've not seen a kit but it's very simple to do, so long as you have a NNN ECU. The early ECU's require the expensive kit. 4 bits of wire, 2 switches for set/increase speed and resume settings then a third that turns it all off. You'll also need some ECU pins which Martin supplies via the site shop or can be found on eBay.
I used a Carling switch for the on/off and a Disco 2 switch mounted on the column like the photo Steve_C3 posted earlier.
There's a wiring diagram here http://www.defender2.net/forum/topic2974-15.html 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #676573 7th Jan 2018 12:07pm
MT
I'm also interested in hearing if anyone has solved the issue with cruise cancelling when the window switches are used. I have the same issue, again never really bothered me but suspect an earth issue somewhere. If I get time I might pull the dash apart to investigate...
Post #678283 14th Jan 2018 12:09am
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
Well I finally was allowed time to look at it. I tried running a new earth and it made no difference at all. When I tried it further it only disengages when the window reaches it full travel, either up or down, and you keep the button depressed. Glad to hear I'm not alone with this. I shall graciously admit defeat and live with it and accept it as a foible of the car and aftermarket cruise installation.
Post #679507 17th Jan 2018 10:56pm
AJC
Those people that have used the Disco 2 cruise switch, have you just cut the plug off and used a different connector?
Post #679539 18th Jan 2018 6:37am
AJC
Also, how did you find mounting the D2 switch, I assume you use the sandwich plate shown in the picture?
Post #679540 18th Jan 2018 6:41am
Harry.O
Hi AJC, Yep I cut off the old connector and used crimps.
I'm sure there are different ways to mount it, I was in a hurry and used a 90' bracket with some self tappers, a few pics below. Couldn't figure out how to install the Disco on/off switch neatly into the dash so opted for a Carling switch to cut the power and prevent CC being engaged by accident.
I threw away the rubber gasket that come with the D2 switch and screwed it to the bracket
Chop a rough hole in the cowling with Dremel
Attach bracket to lower cowling. The 2 parts of the cowling don't make a flat face so I shaved the mounting face of the switch to get a closer fit then tidied up the hole in the cowling.
There is a small piece of the column that needed notching to clear the metal bracket, not a problem with a late TD5 dash but the early ones may interfere with the column mounted fog light switch.
And the finished item, hope that helps Thumbs Up
Post #679592 18th Jan 2018 11:39am
AJC
That's awesome harry, thanks.
I just need to wait for payday to buy the disco switch and the speedo healer and I'm done
Post #679634 18th Jan 2018 3:11pm
mk1collector
I'm going to have to stop coming on this site Big Cry I've just bought the switches Rolling Eyes need to buy a speedo healer now Big Cry Ray
My build thread
Post #679643 18th Jan 2018 3:54pm
AJC
Think I'm going fo rthis one
https://www.ebay.co.uk/itm/263270671183
Post #679648 18th Jan 2018 4:08pm
mk1collector
Yeah that's the one I was looking at too. Ray
My build thread
Post #679672 18th Jan 2018 5:52pm
mk1collector
Also need to figure out where each wire goes as I've either missed something or the wiring diagram mentioned above didn't have enough wires in it. Ray
My build thread
Post #679673 18th Jan 2018 5:56pm
geobloke
You can save a fiver from Craddocks - https://www.johncraddockltd.co.uk/land-rov...-play.html
Every little helps and all...
Post #679675 18th Jan 2018 5:57pm
mk1collector
Thankyou Thumbs Up Ray
My build thread
Post #679679 18th Jan 2018 6:15pm
AJC
Thanks Geobloke
Post #679701 18th Jan 2018 7:18pm
geobloke
Thats 3 of us planning the same mod... wonder if a forum sponsor fancies doing us a deal?! Rolling Eyes
Post #679702 18th Jan 2018 7:21pm
Page 2 of 4 <1234>
