Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
Direct to battery for temps? 2002 90 Td5 Station Wagon
16th Jan 2018 7:45pm |
I've just got to seek out an ignition live in the drivers side fuse box but don't fancy checking the wires with water dripping down my neck Ray
16th Jan 2018 7:47pm |
It's only 12V 2002 90 Td5 Station Wagon
17th Jan 2018 3:12pm |
It's not the electrocution I'm worried about, I just don't like the cold Ray
17th Jan 2018 4:20pm |
17th Jan 2018 5:25pm |
I finally have a bright clock.... That's clock to match the rest of the gauges
Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
23rd Jan 2018 7:25pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
Nice one Ray, that looks much better 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
24th Jan 2018 8:54pm |
Certainly more even Now i need to either fit a new bulb or buy a new hazard switch as now the rest are bright I noticed its bulb had gone Ray
25th Jan 2018 8:37pm |
tried to reverse on my drive today and it felt like I'd left the handbrake on. Got out and had a look round to find this
Click image to enlarge It wasn't pleasant changing the wheel in the snow and sleet! Found this on the inside. Click image to enlarge I suppose luckily there was only maybe 2 or 3 years left on the tread so 2 new tyres ordered at about £300 I've decided to go for bfg k02's this time. Ray My build thread http://www.defender2.net/forum/topic17615.html |
31st Jan 2018 5:42pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 714 |
You won't regret the bfgs, best tyre I've run on my 110
31st Jan 2018 7:17pm |
I read quite a few good reviews but it'll only be the two rears for now as the fronts have quite a bit of life in them still. I might get some new 18" wheels before I need the fronts anyway Ray
31st Jan 2018 8:22pm |
It was rather annoying, and because I went for different tyres on the rear I'm going to have to get new ones on the front as it doesn't look right Ray
3rd Feb 2018 11:03am |
A couple bits done this week. First the obvious one, the new tyres were fitted and look great, the only problem is they look a lot more aggressive than the continentals so I think I'm definitely going to get another pair for the front and see if I can get a few quid back on the ones I take off as they aren't that old and have loads of tread left.
Click image to enlarge Secondly, thanks to litch on here for the great deal on the mud tunnel tray. I was going to order one in the next couple of weeks anyway and his came up in the for sale section just at the right time and with the two 12v plugs just like I wanted! Click image to enlarge Thanks for looking Ray My build thread http://www.defender2.net/forum/topic17615.html |
4th Feb 2018 12:12am |
My alarm had been getting harder and harder to switch on and off with the fob lately, I had to stand right next to the defender in a certain position to make it work. I tried new battery's and nothing changed so I thought I'd try a new fob and yay back to normal distance locking
Strange thing I found with programming the fob with my nanocom though, I'd had the nanocom out in the garage over the winter and when I plugged it into the obd it was taking ages to load up. After twenty minutes I gave up and brought the nanocom into the house. I tried again this morning and everything loaded up and the fob was programmed in under a minute! So I'm guessing nanocoms done like being cold. Ray My build thread http://www.defender2.net/forum/topic17615.html |
16th Feb 2018 1:13pm |
