Home > My Defender > Introducing Buggsy my 110 TD5
Page 3 of 12 <123 4 ... 101112>
grafty99
Yes definitely, I will organise something soon. We could meet at our place for a cuppa and a chin wag Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #677821 11th Jan 2018 11:38pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Sounds good Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #677844 12th Jan 2018 9:01am
geobloke
grafty99 wrote:
Also the switches look like laser etched D2 switches ( same as td5 heated seat ones but blank to begin with Thumbs Up )
Quite possibly. All I could find last night was AMR3600 which is a range rover and rover 200/400 interior light switch.
Post #677854 12th Jan 2018 10:27am
geobloke
Mash wrote:
Definitely need to do a meet at some point Thumbs Up
No idea about the switches if I get time over the weekend I will see if there is any part numbers on them.
Thumbs Up Thumbs Up
Post #677855 12th Jan 2018 10:28am
Mash
Okay little time spent on her today, started to strip out the footwell insulation as it was feeling a little damp and the dash as it seemed a little crusty and found this:
So it looks like my screen bracket seals are leaking and the water is pooling in the dash/insulation oh well only found one small hole:
So think I have caught it in time and I can just treat the rust and patch this hole, the rest of the bulkhead is solid externally so I think it was just due to the leaks that it has some rust.
And for managed to take a pic of the switch part numbers:
D3 Hse - Fiona
Capri 2l S - Anna
Post #677987 12th Jan 2018 7:28pm
dorsetsmith
range rover classic switches Question
Post #678008 12th Jan 2018 8:37pm
Mash
Part number comes back with L/H disco 2 heated seat switch. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #678014 12th Jan 2018 8:52pm
geobloke
They are indeed heated seat switches with (i suspect) laser etched covers and a hole for the indicator light. Neat solution.
I notice the panel is actually tapered to fit the TD5 dash too. Whoever did this, did it well. Thumbs Up
Post #678035 12th Jan 2018 9:59pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Hk07
Blimey Mash, what a mess, how old is it?
Hope you can get to it all and stop it before it gets too bad.
It needed you that one Thumbs Up Thumbs Up Thumbs Up 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #678116 13th Jan 2018 12:18pm
HK07
Hk07
Sorry, just seen it's a 2002. Must have been leaking for years to get like that.
Must get my bolts out on my 07 and have a look, if all is ok put them back with plenty of sealant.
Interesting vehicle, what will you use it for? 2007 90 Puma - Love it - Best car I have ever owned.
Post #678118 13th Jan 2018 12:25pm
I can't help thinking that the front support arms for the extended roof rack have contributed greatly to your rust issues...
Post #678136 13th Jan 2018 1:46pm
HK07
Hk07
But the rust and water marks are quite bad above those non LR bolts 2007 90 Puma - Love it - Best car I have ever owned.
Post #678139 13th Jan 2018 1:49pm
Procta
mash did you get this started up? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #678234 13th Jan 2018 8:08pm
Mash
Update time, oh how I love having a workshop to use in this weather, pushing this beast in and out however is not so fun.
So as I am awaiting a few bits on the engine side I thought I’d carry on with my war against rust, door cards off and out came a wire brush and a tube of rust converter:
The drivers door is very bad and will take a lot of work to recover, both doors have been welded in the usual area they tend to crack.
I then moved on to the dash that has rotted badly, tried to price these up and I can only find them around £1300 Shocked
So I shall do my best to repair this one, the left hand section that covers the wiper motor, well on the older ones is beyond saving so I will have to get a new one at some point.
So with all of that done I thought I would move onto the rear door, this has an additional lock on the rear an at some point the key was lost so I have not been able to open the door, so a little bit of time and I was in.
Stripped off the door card and:
It’s like new so that’s a bonus, well apart from a few dents.
With the back now fully open I could sort out the back and see what I am missing from the front end, so I found most parts but now need to get the two top brackets and Top radiator bracket, oh well. I did also find a bag of seals and copper washers so it would be rude not to try eh:
All seals and copper washers swapped over, now at this point I am finding more and more bodges and cut corners on Buggsy making me wonder what else might be wrong, the egr has failed a while ago and the inlet manifold was filled thick black sludge, a quick clean and a few new bolts to replace some of the missing ones and I thought I’d give it a try.
She runs Thumbs Up as you can see she’s currently putting out more smoke than a chally 2 on start up but she runs. Now my injectors are not coded to my ecu and for some reason I have 3 green Top and 2 black Top injectors, the white smoke stinks of diesel and it doesn’t seem to be drinking coolant so now a bit more fault finding is required. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #678250 13th Jan 2018 9:27pm
Mash
Re: Hk07
The current plan is to do it up as a mobile mechanics truck, my job role might be changing and depending what I move onto I will be doing some mechanics on the side, this wagon just came up at the right price, and so far I’m still well within the cost of buying a runner. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #678252 13th Jan 2018 9:32pm
