Home > My Defender > Introducing Buggsy my 110 TD5
Page 1 of 12 123 ... 101112>
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Ok well turns out this is my 3rd Defender (well ones a 90 not strictly a Defender) anyhoo.....
This is Buggsy:
She’s a 2002 td5 ex electric board, with a possible job change in the not to distant future I decided I need a new work truck so will now spend time sorting this out into a good workshop truck in between fixing Maggie.
Purchased on eBay with a random bid completely unseen and a known Non-runner I collected her prior to xmas but had no time to do anything with her until today, I Knew the AS10 modual was not functional so purchased a set of vehicle ecu and AS10. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #677582 10th Jan 2018 10:31pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Nice purposeful looking Landy. Hopefully not too much £££ to get to the way you need it Thumbs Up
Post #677587 10th Jan 2018 10:47pm
Mash
So fitted Both Ecu and AS10 she cranked but didn’t fire, no faults on Nanocom and ecu not immobilised.
Ok so fuel pump wizzing away nicely, relays functioning and still not firing, read a few posts on here;
Fuel filter:
Yea needs a change me thinks,
Contents looks healthy Rolling with laughter
Checked the fuel coming from the new filter and all good again.
Air bleed valve:
I stripped and checked it over and seems ok, one post said you shouldn’t be able to blow through it and as I tighten the Union CRACK Censored Censored the housing has snapped where it mounts to the chassis, what a Censored design Land Rover now I need to buy a new one at over £100 Big Cry
Injector harness/oil ingress:
Small amount of oil on injector to harness connection, cleaned off and none found at ecu end.
New earth for Ecu:
Made no difference.
Fuel pressure regulator:
Ok so the fuel system image I found one here shows that the pipe work was fitted incorrectly mine ran from the top of the two unions to the cooler and the images show the chassis pipe from pump should go to there so switch those around and fingers crossed it will work, check I have fuel on the return line and all is good.
Still not firing, I have no faults on Nanocom, fuel now good (unless I read diagram wrong), cranks strong doesn’t appear to be anything sluggish with starter, yellow relays operate, crash kill switch under bonnet correctly set, known good ecu and AS10 (paired)...... so please say I have forgotten something very simple it does appear to want to start following the bleeding procedure but never fires up. Oh yes loads of fuel in the tank.
I haven’t tried bump starting as it was a little hard on my own Laughing
As I was not successful in getting her running I thought I would add a few bits I have already laying around:
Started with a simple one the tail lights are a little faded so swapped them over for some nice ones:
Dash next as I have an Egr delete kit with an outlet for a boost gauge, Radio was hanging out so thought I’d have a little look why it didn’t work, once it was out I found this:
One day I will have a vehicle without bodged and dodgy electrics Banging Head
Onto fitting the gauge I placed it in the hole for the clock as a boost gauge is more fun than a clock, also tightened up the speedo as it was 90 degrees out and very loose. (Forgot pics so will take some tomorrow).
EGR delete:
Removed the old one easily, put fingers inside the inlet manifold and some thick sludge was covering it, ok inlet manifold off, hmm two bolts missing from fuel cooler bracket, another two missing from the manifold, dipstick tube bolt packed out with washers rather than being cut down......... hmmmm few bodge jobs to overcome. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #677592 10th Jan 2018 11:06pm
Mash
Cheers, I am hoping not but I got it for a steal price much below what a basic hard top goes for, just saving for a house means shoe string budget and upgrades over time not all at once Big Cry 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #677595 10th Jan 2018 11:09pm
geobloke
Interesting switches and panel Mash... not seen those before, looks almost OE...
Post #677597 10th Jan 2018 11:13pm
cabell
Very interesting lower switch panel indeed... really does look like it belongs there. What could this be from?
Post #677609 11th Jan 2018 12:02am
Procta
mash, do these have a another fuel pump in the engine bay? That could be at fault if it has one. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #677619 11th Jan 2018 6:00am
dorsetsmith
have you check crankshaft CKP sensor will not send fault code ECM
https://1drv.ms/i/s!AtZSoWFHDgnGhRjwzXNzfb8BiBM-
Post #677640 11th Jan 2018 10:28am
Mash
Procta, no these only have the pump in the tank.
Dorsetsmith I haven’t yet but will try tonight Thumbs Up
I have ordered new injector seals and a loom so I will change those as a matter of course. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #677650 11th Jan 2018 12:07pm
Mash
The vehicle is a special vehicle build so I assume it was fitted by them. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #677653 11th Jan 2018 12:09pm
geobloke
Could I trouble you for a better photo or two of them please?
Post #677654 11th Jan 2018 12:23pm
Mash
Yes no problem is it just the lower switches you want to see? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #677666 11th Jan 2018 1:14pm
excossack
Crank sensor? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #677668 11th Jan 2018 1:20pm
dorsetsmith
just in case the link stops working
Post #677669 11th Jan 2018 1:34pm
geobloke
Yes that's right. Thanks Mash. Thumbs Up
Post #677685 11th Jan 2018 3:21pm
