![]() | Home > Maintenance & Modifications > Britpart Cubby Box Install |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The genuine ones aren't the most robust either, I expect it's from the same supplier. It should pull out.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
It is normally glued down. I had to lever mine out to drill some screw holes beneath it for the mounting screws. You could re-glue if you wanted but i habe left mine loose so i can get to the screws to remove.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 ![]() ![]() ![]() |
It's glued down with two big splodges of hot glue. I removed mine to run the wires in for my heated seat switches without too much hassle.
I ended up drilling the removable centre panel and screwing the cubby box down upwards from below |
hinsonberger Member Since: 31 Mar 2017 Location: Thames Posts: 32 ![]() ![]() ![]() |
Thanks guys! I just need to be a bit more brutal by the sounds of it
![]() I'll give it a go & report back. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 784 ![]() ![]() ![]() |
As said, the cup holder is held in with a couple of blobs of hot glue, I popped mine out with levering with something wide, like a wallpaper scraper to reduce the risk of damage.
Success!!
As suggested, with the use of a wide scraper, some constant pressure & some cloth to protect the vinyl; the cup holder came out. Thanks for the tips. |
