Home > Technical > Relays 2008 Puma |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4664 |
Could someone tell me what the three relays under the front passenger seat on a 2008 Puma are for? There are two black ones and a smaller grey one. Thanks 1982 88" 2.25 diesel
5th Jan 2018 5:04pm |
You are right! I ment to say DRIVER'S SEAT BOX!!!! 1982 88" 2.25 diesel
6th Jan 2018 10:13am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
Just to make it a little confusing, to me (LHD) it actually IS the passenger side and it's called the Battery Junction Box, although the batteries aren't there
Anyway, this might help: http://www.defender2.net/forum/topic33868.html But there are ten relays, not just three, as you mention |
6th Jan 2018 2:34pm |
have look at old post below http://www.defender2.net/forum/topic57192....elays+puma |
6th Jan 2018 3:45pm |
Many thanks. I'm actually looking for the wiper relay. I have a problem and I need to figure out if it's the relay or the switch. Thought it would be easier to swop the relay from a second Puma to see if it is the relay. If not I'll order in a switch. 1982 88" 2.25 diesel
6th Jan 2018 3:52pm |
i will find you under dash relays i think wiper relay in this place
one drive not work i think second row down second one from left under dash relays |
6th Jan 2018 3:56pm |
Ah, so the BJB was changed with the 2.2, not with the 2.4?
And the "Central Junction Box" under the dash? Here it just says "2007-2016" and it looks like my 2015: https://www.landroverworkshop.com/diagrams...uses_44949 There top row is (from left to right): D247 timer heated front screen D113 delay windscreen wiper R141 relay hazard warning |
6th Jan 2018 8:13pm |
Changed the relays and the problem was still there so I must order in a wiper switch. Everything works except for the very fast wiper action. It does not bother me but it is probably a fail in the vehicle test, ie the M.O.T
Thanks to all who contributed. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
7th Jan 2018 12:42pm |
