![]() | Home > Maintenance & Modifications > Rear crossmember paint ?? |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
On the inside of mine i have wax oiled it, external a good primer and satin black paint u Pol i think i used last time
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Inside I spray with acf50 outside was etch primed where needed and then several coats of black smoothrite. Still good after 3 or 4 winters. 2005 Td5 90 XS
Steve |
Staftly Member Since: 06 Jul 2012 Location: Lancashire Posts: 55 ![]() ![]() ![]() |
I would avoid dinitrol. I covered by chassis from new with dinitrol and sprayed the outside of the rear cross member also. Whilst it provides excellent protection, it scuffs quite bad and looks shoddy after a while. Use on the inside fine, use something else on the visible parts.
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
![]() Click image to enlarge Keying of the original fading paint using green scotch pad then spray up using POR 15 chassis black aerosol. then I give it a ACF50 spray every so often. The inside has been Dynaxed thoroughly |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
I used buzzweld CIO. Good stuff, applies well, has a nice finish and hasn’t yet started to fade. This is now 6-8 months down the line
Well buzzweld is 99% Corroless paint anyway the marketing jargon and product names are too close to say they are not. It's just fancy marketing.
Browse through the Corroless website and their product page you can get the jist of how good it is. Now arc rite sell this stuff in small amounts so some Google fu and Boom Corroless all in one chassis paint Simples ![]() |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 ![]() ![]() ![]() |
Thanks for you all your replies. I’m going to use the buzzweld I have and do it again in the spring. ACF 50 ? What are the results and where can it be used. Is it like dinitrol or paint ?
Alex |
ACF 50 is a corrosion inhibitor spray and lubricant, like an expensive WD40 ! Works well in enclosed areas as it has a low viscosity and will run in to corners well would not work so well in exposed areas as it would get washed off. I usually buy it from amazon in aerosol cans but can be bought in larger quantities. 2005 Td5 90 XS
Steve |
Excellent I have ordered some for the Bulkhead. Last what is the best thing so spray on the inside of the wheel arches? The tub basically.
I’ve never really applied anything to the tub itself as it’s alloy but it is worth getting something in to the steel floor reinforcing struts under the rear floor to protect them.
If I was to do the rear arches would probably go with a good quality stone chip type coating as this would protect from abrasion and would have a sound deadening effect too. I think dinitrol do this type of coating. 2005 Td5 90 XS Steve |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
Go for buzzweld! ! I am more than happy with the result
http://www.defender2.net/forum/topic12989-90.html www.newfoundland.gr |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Rubbed mine down to bright steel, then sprayed with a couple of coats of Zinc 182, then just sprayed it with Upol Satin black. Dinitrol the bits you can't see.
Still looks as good as new 18 months later. ![]() Click image to enlarge |
capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223 ![]() ![]() ![]() |
Same 2015 90 Hard Top 1998 90 300Tdi - chuffed to have another one 2013 Freelander 2 - for posher trips to the shop 1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it 2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit 2010 90 Hard Top - now sold Ex mil 90 - now sold |
90Ben Member Since: 01 Jan 2015 Location: Nottinghamshire Posts: 26 ![]() ![]() |
![]() Click image to enlarge 2010MY Defender 90 Stornoway |
