Home > Maintenance & Modifications > Rear crossmember paint ??
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
My rear cross member needs a fresh coat of paint , do I use a zinc 182 primer then buzz weld it? Or waxoyl or dintrol ? I’m looking for long term protection.
Anyone able to recommend the best way to protect ?
Many thanks Alex
Post #673687 27th Dec 2017 10:50pm
JAY BOY
Wales
On the inside of mine i have wax oiled it, external a good primer and satin black paint u Pol i think i used last time
Thumbs Up
Post #673692 27th Dec 2017 11:00pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Inside I spray with acf50 outside was etch primed where needed and then several coats of black smoothrite. Still good after 3 or 4 winters. 2005 Td5 90 XS
Steve
Post #673698 27th Dec 2017 11:14pm
Staftly
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Dinitrol but not on visible areas
I would avoid dinitrol. I covered by chassis from new with dinitrol and sprayed the outside of the rear cross member also. Whilst it provides excellent protection, it scuffs quite bad and looks shoddy after a while. Use on the inside fine, use something else on the visible parts.
Post #673709 28th Dec 2017 12:19am
Devon-Rover
Keying of the original fading paint using green scotch pad then spray up using POR 15 chassis black aerosol. then I give it a ACF50 spray every so often. The inside has been Dynaxed thoroughly
Post #673758 28th Dec 2017 11:35am
isacs
I used buzzweld CIO. Good stuff, applies well, has a nice finish and hasn’t yet started to fade. This is now 6-8 months down the line
Post #673768 28th Dec 2017 12:08pm
Devon-Rover
Well buzzweld is 99% Corroless paint anyway the marketing jargon and product names are too close to say they are not. It's just fancy marketing.
Browse through the Corroless website and their product page you can get the jist of how good it is.
Now arc rite sell this stuff in small amounts so some Google fu and Boom Corroless all in one chassis paint
Simples Thumbs Up
Post #673779 28th Dec 2017 1:16pm
Alextd5
Crossmember
Thanks for you all your replies. I’m going to use the buzzweld I have and do it again in the spring. ACF 50 ? What are the results and where can it be used. Is it like dinitrol or paint ?
Alex
Post #673789 28th Dec 2017 3:08pm
Lou Sparts
ACF 50 is a corrosion inhibitor spray and lubricant, like an expensive WD40 ! Works well in enclosed areas as it has a low viscosity and will run in to corners well would not work so well in exposed areas as it would get washed off. I usually buy it from amazon in aerosol cans but can be bought in larger quantities. 2005 Td5 90 XS
Steve
Post #673797 28th Dec 2017 3:44pm
Alextd5
Excellent I have ordered some for the Bulkhead. Last what is the best thing so spray on the inside of the wheel arches? The tub basically.
Post #673802 28th Dec 2017 4:12pm
Lou Sparts
I’ve never really applied anything to the tub itself as it’s alloy but it is worth getting something in to the steel floor reinforcing struts under the rear floor to protect them.
If I was to do the rear arches would probably go with a good quality stone chip type coating as this would protect from abrasion and would have a sound deadening effect too. I think dinitrol do this type of coating. 2005 Td5 90 XS
Steve
Post #673805 28th Dec 2017 4:23pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Go for buzzweld! ! I am more than happy with the result
http://www.defender2.net/forum/topic12989-90.html www.newfoundland.gr
Post #673897 28th Dec 2017 9:10pm
zsd-puma
Rubbed mine down to bright steel, then sprayed with a couple of coats of Zinc 182, then just sprayed it with Upol Satin black. Dinitrol the bits you can't see.
Still looks as good as new 18 months later.
Post #673977 28th Dec 2017 11:35pm
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Thumbs Up
Same 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one
2013 Freelander 2 - for posher trips to the shop
1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it
2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit
2010 90 Hard Top - now sold
Ex mil 90 - now sold
Post #674469 30th Dec 2017 7:58pm
90Ben
 2010MY Defender 90 Stornoway
Post #674911 1st Jan 2018 12:11pm
