Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1430 |
Nope, It's society as a whole ......"everyone dose it" so that makes it OK
I'd quite happily be a hermit |
7th Dec 2017 7:12pm |
I might need it I'm starting to clear stuff out honest. Ray
7th Dec 2017 9:06pm |
Fitted the light but not wired up yet as my nose and fingers were that cold I thought they were going to drop off.
Click image to enlarge I asked my twin 13yo daughters to have a go at marking out to drill the holes first and gave them half an hour all I can say is what are schools for now a days, they could barely read a tape measure time to get them doing a few jobs in the garage next summer so they learn something other than copying what's on a board! Ray My build thread http://www.defender2.net/forum/topic17615.html |
9th Dec 2017 6:01pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
Looks good What will you do about the washer jet? I've always thought on the rear door would be a good place, hidden by the spare too 2002 90 Td5 Station Wagon
9th Dec 2017 10:21pm |
To be honest I don't think I've used the rear washer once in the last 5 years so I was just going to leave it off. I figure if I ever want to take the light back off I've just got two small rivets to put in and paint and the washer jet can go back on. Ray
9th Dec 2017 11:47pm |
9th Dec 2017 11:55pm |
It lives
Click image to enlarge Just need to fit my switches where I want them now Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th Dec 2017 4:55pm |
That looks bright 2002 90 Td5 Station Wagon
13th Dec 2017 9:42pm |
It is a bit, I couldn't get a decent shot with my phone because of the brightness Ray
13th Dec 2017 11:15pm |
Are you going to have it on a three way switch?
On with reverse, off or on manual? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Dec 2017 11:33pm |
I don't think I'll have it on with reverse, I think I'm going to have a switch in the front and one in the boot so I can switch it on from either end when needed. That's if I can work out how to wire it that way Ray
13th Dec 2017 11:59pm |
Depends if you want to be able to switch it on at one end and then off at the other?
I.e if you accidentally leave it on at the back and then get in to drive. You'll want to be able to switch it off from the drivers seat I'm guessing? If so you want two double pole on-on switches that change over circuit as opposed to switch off. This diagram might help 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
14th Dec 2017 10:01am |
I'd like it wired so I have to switch it on and off from the same switch each time, so if I've finished with the light at the back I have to switch it off there etc. Would it be safe and would it work like I'm thinking if I wire it up like this?
Disclaimer: wiring not my best subject Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
14th Dec 2017 12:48pm |
Yeah that would do it. But I think you'd find it handy to be able to turn it off from the other switch. It's only one extra wire to run 2002 90 Td5 Station Wagon
14th Dec 2017 1:00pm |
