Home > Puma (Tdci) > Headlights and dash lights not working |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Sounds like the light switch itself more than anything?
maybe pull the fuses, but it doesn't sound like a fuse issue. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
2nd Dec 2017 7:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20492 |
Yep, sounds like the light switch. No Guts, No Glory.
2nd Dec 2017 7:06pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3330 |
Cheers guys. Do you think a novice like myself be able to fix or should i wait until Monday and take it to the garage?
2nd Dec 2017 7:13pm |
There isn't much you can do with one,
It's pretty much throw away and refit a new unit. Might be worth having a poke about with it in the daylight, Check the plug etc.... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
2nd Dec 2017 7:18pm |
Ok. Thanks Ian.
2nd Dec 2017 7:19pm |
Incredible self healing Defender strikes again! Tried the lights and all working fine.
I'll take it in for a new switch anyway as i don't want to get stranded in the future. |
3rd Dec 2017 2:19pm |
Sounds still like the switch, it's probably cooled down now.
Best to get it replaced. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
3rd Dec 2017 5:19pm |
Will do. Cheers Steve.
3rd Dec 2017 5:54pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Might be worth running the lights via a relay to prevent the switch overheating again
There's a long thread on the subject here http://www.defender2.net/forum/topic26097....ight+relay |
3rd Dec 2017 6:22pm |
