Home > Maintenance & Modifications > Swivel seal retainer plate fixings
Screbble
I'm probably being a bit lazy but....
Does anyone know (off the top of their head) the size of the bolts / set screws that fix the swivel seal retainer plates to the swivel housing? There are 7 of them each side.
I can't get a proper look until the weekend, but I guess they're not far of M6 x 25?
Thanks in advance,
Will
Post #667617 28th Nov 2017 7:54pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Think they are closer to 12 mm long...but i lll see if i have any left over from my recent swivel change to measure...
Patrick
Edit Believe they are m6x12mm FS106125L....
Edit 2.....yes they are listed as flange head and IIRC they are only 8 mm heads on them which round easily if they are badly abused.....
Post #667619 28th Nov 2017 7:57pm
Screbble
Yes that sounds about right - my original post should have said M6 x 15!
Grateful for your help Patrick Thumbs Up
I seem to remember they may be set screws rather than bolts and that the head is unusual?
Post #667620 28th Nov 2017 8:00pm
rallysteve
M6x12 with a flange head (8mm hex)
Post #667632 28th Nov 2017 8:32pm
Screbble
Thank you Steve - that does sound spot on Thumbs Up
Post #667633 28th Nov 2017 8:36pm
