Home > Maintenance & Modifications > Swivel seal retainer plate fixings |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
Think they are closer to 12 mm long...but i lll see if i have any left over from my recent swivel change to measure...
Patrick Edit Believe they are m6x12mm FS106125L.... Edit 2.....yes they are listed as flange head and IIRC they are only 8 mm heads on them which round easily if they are badly abused..... Last edited by Justtellme on 28th Nov 2017 8:03pm. Edited 2 times in total |
28th Nov 2017 7:57pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
Yes that sounds about right - my original post should have said M6 x 15!
Grateful for your help Patrick I seem to remember they may be set screws rather than bolts and that the head is unusual? |
28th Nov 2017 8:00pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2228 |
M6x12 with a flange head (8mm hex)
Steve 02' 110 TD5 Double Cab Rebuild Thread |
28th Nov 2017 8:32pm |
Thank you Steve - that does sound spot on
28th Nov 2017 8:36pm |
