Home > Puma (Tdci) > Just back from Land Rover Experience and now a bit confused. |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
prop and driveshaft slack common on Puma of all ages. Regular greasing of UJs essential
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
26th Nov 2017 4:39pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
Check your rear hub splines too! They're often a cause for lack in the rear . Should be able to find plenty on the forum about it if you do a search.
Also, have a quick search for gearbox output shaft too. It won't just show as rear backlash, but that'll give you a clunk when taking up drive. Ashcroft does upgrades for both. Expensive but worth the reduction of slack and should last quite some time! |
26th Nov 2017 4:48pm |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 827 |
If your defender has been driven hard or badly then could be a simple drive flange or halfshaft spline ware ....
Pop drive flanges off and check and replace if necessary. When pulling away always take up slack don’t just drop the clutch ....hard to explain but Something like brake , clutch up and away you go clunk free Have fun be happy |
26th Nov 2017 4:52pm |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 |
Thank you all for the tips and advice. Greatly appreciated from a novice such as myself.
Still got some warranty so will hit the dealer up again and hopefully sort it out that way before going the aftermarket route. Thanks again, P |
26th Nov 2017 6:06pm |
flyingfab Member Since: 14 Jun 2015 Location: Brittany Posts: 60 |
Hi Perry, This reminds me an idle jack-issue ... Just to be sure : do you actually mean high-range (transfer lever backward) or low-range (transfer lever frontward) ? In the second case, I would say this is a matter of idle-jack instead of anti-stall : on Puma Defender, in order to avoid too much engine brake when driving downhill on idle, the revs are increased by around 200/300 rpm on first gear, anytime the transfer-box is engaged in low-range. If your low-range sensor doesn't work properly, the idle-jack won't activate and, as a result, you won't have the sensation of "lurching ahead" you had on the 110 when releasing clutch. But if you were actually meaning low range, this is probably be a different story. You should tell a dealer about it ... but this is likely to end up like that : - This is normal, they all do that, Sir. - But It happens they don't : mine doesn't do it ! - This is normal, they are all different, Sir. More seriously, and still in that case, are you sure your clutch is in good condition ? (not slipping) Fabien |
27th Nov 2017 10:36am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Sounds like you need a re-map. Transformed mine.
28th Nov 2017 8:09pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
There all different mines over 120 K but the lads at Stonelake say it’s as good and better than some with little miles on.
28th Nov 2017 8:16pm |
the 110's do ride better as standard, much less pitching because of the longer chassis. If it's been driven hard then it gives the engine a good clear out. I found with my Puma engined X-Type as well as my Defender, taking it for a good blast and getting the engine up to temp for a bit makes them run much better.
Little bits of slack in all the different parts of the drive train soon add up. Even wear in the bottom of the gearstick makes a surprising difference. I would think your's probably already has the one piece rear drive shafts? The adaptor shaft between your gearbox and transfer box will likely be worn, and even a bit of play in each of the propshaft UJ's will add to it. |
28th Nov 2017 8:19pm |
Thanks again All for the great tips. I will take it all on board and check out what has been suggested.
In short, no remap yet as I'm still in warranty and all the drivetrain bits are original so likely a bit of wear and tear needs tending. With that said, came away loving the 90 even more after the LR Experience and can't wait to get mine out and hope to do soon! Once again, thanks |
29th Nov 2017 8:44pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8051 |
some experience centres run remapped vehicles, like some dealers run remapped vehicles, its all a sales thing, as was when they were all in production. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th Nov 2017 8:49pm |
