Home > Td5 > Any ideas what this is?
Djcla
Connector inside Engine bay front right corner, just sat there?
Post #665333 18th Nov 2017 5:12pm
dorsetsmith
if the wire colours are red orange and black side light front
Post #665337 18th Nov 2017 5:26pm
Djcla
So one of my lights should be out then?
Post #665346 18th Nov 2017 5:53pm
dorsetsmith
yes but check wire colour just in cage i am wrong
Post #665348 18th Nov 2017 6:00pm
Romadog
Extra horn for alarm ?
Post #665408 18th Nov 2017 9:55pm
My guess is to do with the washer bottle, you can see connections on there with the headlight removed.
But as mentioned, wire colours need checking.
Econoseal connectors are used for sidelights, indicator, horn, and washer bottle pump connections.
All in that vicinity. $W33T $0U7H3RN $UG4R
Post #665409 18th Nov 2017 10:04pm
dorsetsmith
Re: Any ideas what this is?
with mugs in hand and sun up see your pic are front left hand side
Post #665451 19th Nov 2017 7:35am
Djcla
Yes sorry I meant as I was looking at it from the front lol, but yes passenger side front.
Post #665454 19th Nov 2017 7:46am
dorsetsmith
no problem had go to work shop to check paint work on generator canopy it dry Very Happy next one
LH front wing plug and wiring colours 2002 TD5 onwards
LH front ind (wire B / GB) plug black
horn LH/RH (wire B/PB ) plug L Blue
Pump washer F ( wire B / LGB ) plug red
pump washer R ( wire B / BLG ) plug Black
side light front L ( wire B/RB ) plug black
SoAL ( wire B/OB ) plug Black ( not always used ) Banging Head
BBUS ( wire Black ) plug brown
head lamp leaving ( wire UY/B/RO) plug Natural
back out to start rebuilding next generator
Post #665458 19th Nov 2017 8:35am
Djcla
Thanks I'll check tomorrow, can you just clarify the letters codes you have used above?
Post #665506 19th Nov 2017 3:58pm
dorsetsmith
Post #665511 19th Nov 2017 4:12pm
Djcla
Ok it's this one after checking the colours on the wire, now just gotta work out how to access it to reconnect.
Post #666113 21st Nov 2017 8:19pm
Djcla
Well confused now, all my lights are working, including side indicator lights. Wire is black and red/black with black plug. I am colour blind so maybe it orange / black. But looks red to me.
Post #666896 25th Nov 2017 7:50pm
rallysteve
Think you will find it is the plug for the auxiliary alarm sounder which is rarely used.
Post #666901 25th Nov 2017 8:11pm
Romadog
See my previous post Whistle
Post #666927 25th Nov 2017 10:49pm
