Home > Puma (Tdci) > BAS intercooler fitting.
TOP5N
Hi All... I will be fitting my BAS intercooler and silicon hoses over the weekend... can anyone tell me roughly how much time i should allow for this.
Regards,
Chris
Post #665217 17th Nov 2017 10:16pm
Avelingporter
At the Peterborough show the guys from BAS took about 2.5 hours to fit mine. So maybe add another hour or so on top of that if you haven’t done it before.
Good luck.
Post #665220 17th Nov 2017 10:31pm
LR90XS2011
I think there is a thread on here about it with some pointers, if I remember correctly the person posting it dented his wings in the process so be careful DEFENDER 90 TDCI XS,
Post #665234 18th Nov 2017 6:08am
williamthedog
About a mornings work taking it easy as long as it goes well.
Post #665240 18th Nov 2017 7:40am
TOP5N
Good luck.
Was that with the silicon hoses as well...
Thanks
Post #665283 18th Nov 2017 12:51pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
if you changes the hoses, you have to remove the air filter box, taking that out and putting back in is the hardest part.
The slam panel has studs, use double nuts on the studs to remove (lock one onto the other to remove the stud) I replaced the studs with bolts.
If you are changing the hoses you may as well carry out the air box mod to improve airflow while the air box is out
Hole thing took me 6 hours but I was changing all my bolts to stainless and just potching about
So slam panel off,
lean the air con rad forward
remove intercooler
remove air box
fit silicone hoses
locate inter cooler etc
then have a cry while trying to refit the air box wondering how the hell did I get this out
all done
Post #665299 18th Nov 2017 2:21pm
Iktank
So slam panel off,
remove intercooler
remove air box
fit silicone hoses
all done
Post #665300 18th Nov 2017 2:22pm
TOP5N
Thanks for the info Very Happy
Post #665384 18th Nov 2017 7:45pm
M94PUMA
Aa
Post #665407 18th Nov 2017 9:41pm
