Home > Technical > 2.4 Puma knocking/ticking
arran jones
HELLO ALL,
Everyone knows what defender i have....From today i have had a bad problem with my defender 2.4, it started making a loud knocking/ticking noise this morning on the way into work,
topped up the oil as it was low at midday and at 5PM there was no difference on the dipstick....
i came to start it up at the end of the day and it suddenly started making the noise again and the whole engine or car was juddering like crazy..even on a cold engine and standstill in the car park!!
might be getting it towed away tomorrow for a check over
but has anyone on here got any ideas of what it could be..to be honest i am fearing for the worst and if it comes to a new engine then so be it Rolling with laughter
its all part of defender life! hah
any help would be very valued and appreciated..sooner the better Whistle
many thanks in advance
Arran
Post #664655 15th Nov 2017 9:01pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Check your injectors are not loose!
The clamp bolt can undo, which results in a very Nasty knocking.
You will see, or feel your injectors bouncing. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #664657 15th Nov 2017 9:06pm
mk1collector
As above, Prezzy on here just had the same thing a couple of days ago on his svx. He popped it into the Landrover centre who got them all rebolted in the day Ray
My build thread
Post #664697 15th Nov 2017 10:49pm
Surely though they shouldn't come loose anyway! No doubt another Defender foible though. Laughing TheThunder Rolls🇬🇧🇺🇸
Post #664702 15th Nov 2017 11:34pm
Plus, I very much doubt it'll come to a new engine. TheThunder Rolls🇬🇧🇺🇸
Post #664703 15th Nov 2017 11:34pm
agentmulder
Kuwait
Have a look under here:
If they be like that fasten em up a bit, but don't go nuts or you'll break the torque to yeild bolt.
Couple of threads on the forum already... Other than that, good luck finding it! Solved the bowel problem, working on the consonants...
Post #664713 16th Nov 2017 5:42am
arran jones
Thanks all for your help..its being towed away today hopefully so will see if your both right..
Will let u know the outcome Thumbs Up
Post #664726 16th Nov 2017 7:49am
Harald
Belgium 2010 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
IF it was the 'injector problem' also take some time to:
Drain engine oil (use motorflush before)
Remove oil sump and clean inside
Remove and clean the oil pump strainer.
Install everything back.
Refill with (new) engine oil.
Maybe you could make some pictures how the oil pump strainer looked like before the cleaning (I forgot to do that myself Embarassed ).
Good luck!
PS Don't forget to also change the cupper rings under the injectors, the 'original' LR are really expensive, but sometimes you can find them much cheaper on the WWW.
Post #664789 16th Nov 2017 12:55pm
arran jones
Hello all gr8 chaps
Ild like to thank you all for your advice and everyone of you are right! Thumbs Up
It was loose injector clamp bolts
U all know your stuff on here..very good at guessing problems Thumbs Up
Post #665137 17th Nov 2017 5:37pm
ian series 1
Just stick the money in the post cheers.... Laughing
Glad you got it sorted Thumbs Up 80" 80" 86" 88" 90"
Post #665138 17th Nov 2017 5:44pm
Excellent news, at least you don't need a new engine now. Whistle
Thumbs Up Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #665143 17th Nov 2017 5:51pm
arran jones
Ahha yeppp
Whats your address ian...
Jokes Rolling with laughter
Post #665156 17th Nov 2017 6:25pm
prezzy
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Glad you got it sorted. Thumbs Up
I also looked on here to find out the diagnosis. Bow down
Post #665193 17th Nov 2017 9:01pm
Johan H
Finland
Hello chaps,
Excellent thread, my Puma has the same as in the video. The knocking is horribly loud, I thought it was the end of the engine...
Anything else I should have in mind when doing this?
Thanks in advance for the help
Post #806355 15th Dec 2019 7:16pm
