![]() | Home > Technical > 2.4 Puma knocking/ticking |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Check your injectors are not loose!
The clamp bolt can undo, which results in a very Nasty knocking. You will see, or feel your injectors bouncing. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
As above, Prezzy on here just had the same thing a couple of days ago on his svx. He popped it into the Landrover centre who got them all rebolted in the day Ray
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
Surely though they shouldn't come loose anyway! No doubt another Defender foible though.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Plus, I very much doubt it'll come to a new engine. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Have a look under here:
If they be like that fasten em up a bit, but don't go nuts or you'll break the torque to yeild bolt. Couple of threads on the forum already... Other than that, good luck finding it! Solved the bowel problem, working on the consonants... |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Thanks all for your help..its being towed away today hopefully so will see if your both right..
Will let u know the outcome ![]() |
Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81 ![]() ![]() ![]() |
IF it was the 'injector problem' also take some time to:
Drain engine oil (use motorflush before) Remove oil sump and clean inside Remove and clean the oil pump strainer. Install everything back. Refill with (new) engine oil. Maybe you could make some pictures how the oil pump strainer looked like before the cleaning (I forgot to do that myself ![]() Good luck! PS Don't forget to also change the cupper rings under the injectors, the 'original' LR are really expensive, but sometimes you can find them much cheaper on the WWW. |
Hello all gr8 chaps
Ild like to thank you all for your advice and everyone of you are right! ![]() It was loose injector clamp bolts U all know your stuff on here..very good at guessing problems ![]() |
Just stick the money in the post cheers....
![]() Glad you got it sorted ![]() Wanted, Forward Control Anything considered. |
Excellent news, at least you don't need a new engine now.
![]() ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Ahha yeppp
Whats your address ian... Jokes ![]() |
prezzy Member Since: 04 Jan 2010 Location: Huddersfield Posts: 126 ![]() ![]() ![]() |
Glad you got it sorted.
![]() I also looked on here to find out the diagnosis. ![]() |
Johan H Member Since: 12 Oct 2017 Location: Helsingfors Posts: 36 ![]() ![]() |
Hello chaps, Excellent thread, my Puma has the same as in the video. The knocking is horribly loud, I thought it was the end of the engine... Anything else I should have in mind when doing this? Thanks in advance for the help |
Fulltensor Member Since: 11 Mar 2025 Location: Houston Posts: 3 ![]() ![]() ![]() |
I have the same problem of making kicking noise on my 2.2 Puma[/img]
