Home > Puma (Tdci) > Mud flap mounting |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
Of course, happy to wait.. |
27th Mar 2011 10:16pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
What about rears for 130s as well.
27th Mar 2011 10:46pm |
Red Desert Member Since: 23 Aug 2010 Location: Lake Constance Posts: 53 |
must have a look at......should be no problem
29th Mar 2011 4:31pm |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
I have just had the same problem on my TD5 110. Had a strange creaking noise when parked - it was the nearside rear flap swinging loose having just "munched" about 2 " of lower rear qtr panel off
So, put me down for brackets, re-inforcement & flaps - I might as well do the job properly, as I only want to do it once! 2001 TD5 110 DCPU in Bonatti Grey |
4th Apr 2011 9:46am |
Markh Member Since: 24 Jul 2010 Location: Grantham Posts: 33 |
My rear offside broke loose, identical to previous post pictures, sheared at the panel, 110 9 months old 14k miles. Took it to the dealer (assuming) obvious warrantee fix .... to be fair dealer was great but Land rover warrantee said no way, I must have done it ... Lots of photographs and arguing later they sent a regional engineer out to look who agreed it wasn't me, it was a warrantee claim. Ended up with some aluminium welding on the panel and a mod to the bracket fitting a T piece at the end. Couple of months later all sorted now (under warrantee) but was a pain to get done! "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
6th Apr 2011 9:52pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5575 |
Will these new Red Desert brackets fit a Td5 90??
If so I'll have a pair please Andy |
7th Apr 2011 5:08am |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
can i put an order in for a set for a 110, please.
cheers alan. |
7th Apr 2011 8:46am |
alwyas thought, that the rear mudflaps for the 90 are positioned on the frame......?
7th Apr 2011 4:48pm |
the brackets are in production.......give them 10-14 days
7th Apr 2011 4:49pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
On my 90 XS the rear mudflaps are bolted into the rear crossmember using rivnuts in the crossmember.
7th Apr 2011 9:13pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2109 |
Red Dessert,
Can you sent those brackets to Chile? Cost? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
7th Apr 2011 9:40pm |
we will have stainless steel brackets for the 90 in about 10-14 days
8th Apr 2011 9:43am |
€ 7.- (worldletter)
8th Apr 2011 9:49am |
finished: http://www.entreq.de/products/protection/s...er-90.html |
13th Apr 2011 9:27am |
