Home > Td5 > Hub mess
Page 3 of 3 <123
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
A friend of mine has fitted heavy duty drive flanges and tapped a grease nipple into them, a neat and functional mod. I plan to do it on mine ........... one day!! 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #658731 21st Oct 2017 11:54am
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Like these?
Post #658808 21st Oct 2017 7:19pm
Screbble
Like many others, the OP has now focussed my attention towards and area that has not been given the focus it deserves.
I intend to give the hubs the 'once over' shortly and I have a couple of questions.
I note that some are adding a grease nipple to the driving member. This can't be a bad thing at all, but I'm struggling to understand where, on the front at least, the grease is going to lubricate and protect. Is it going beyond the circlip, spacer and spline area? I can't see how it can. Apologies if this is a stupid question Neutral
I suppose the same question can be asked for the rear, but I can visualise a route for the grease towards the bearings. But the reality is, I've never looked! Shame on me Embarassed
Secondly, what would others recommend to be the absolute minimum attention we should give the hubs, including frequency etc. and then what would be considered best practice? I don't do a lot of miles, but I do like to keep things well maintained - or at least that is my intention! Very Happy
Many thanks in advance,
Will
Post #658867 22nd Oct 2017 7:29am
Leviathan
As I understand, and this was certainly the case with mine, its just the contact between the drive shaft splines and the outer drive flange that gets neglected. If left they will fuse together with rust.
I would say once a year is enough to undo the 5 bolts on the drive flange, remove the circlip, clean and regrease.
The grease nipple idea is only for the HD flanges with the metal screw on cap. I dont think there is any intention of greasing wheel bearings with this. OK if you want some but unnecessary imo.
Post #658886 22nd Oct 2017 9:53am
Screbble
Thanks Leviathan,
Yes that makes sense.
I have gaskets and spare bolts in the garage, so I'll have a look over the next week or so.
New/replacement driving members don't appear to be overly expensive so I wonder if I should replace them as they are coming off anyway. No harm in having a couple spare I guess.
I've seen quite a few HD versions on the bay of e for circa £75 per axle set (inc. bolts, gaskets, circlip etc.) but I'm not sure I'd benefit from that investment. I can see why others would opt for these over std. I can also appreciate that they'd look 'nice' with some aftermarket alloys!
Any recommendations for the grease? I have plenty of different types in the garage.
Cheers,
Will.
Post #658889 22nd Oct 2017 10:39am
dorsetsmith
i use water resistant grease pack small amount into the cap also used in boat trailer wheel bearing ,replacing caps good too munch tighter fit on to the drive mender
Post #658892 22nd Oct 2017 10:54am
Bows
cobra_mark wrote:
Like these?
Yes 2006 TD5110 station wagon
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #659682 25th Oct 2017 9:03pm
Page 3 of 3 <123
