Home > Puma (Tdci) > Typical: Friday afternoon at 4.30......
Farmer58za
South Africa 2012 Defender 90 Puma 2.2 SW Tamar Blue
Hi All
I got an engine malfunction light late this afternoon. No funny noises, performance drop, temperature increase or limp mode. Just a light.
I looked at some other threads about restarting a number of cycles to clear the fault, as well as the distinct possibility of it being the MAF or EGR.
What's the best cheap diagnostic tool that's available out there? The Foxwell nt204 looks pretty good at less than 50 GBP.
Any recommendations?
If I don't sort it out over the weekend, I will go off to the local indie LR garage on Monday...
Regards
David Dave's not here man...
Post #658616 20th Oct 2017 5:40pm
X4SKP
Hello Farmer58za
I have the ScanGaugeII and really like it...bought to answer a similar situation to yours
(maybe even the same... Question )
This is worth a look...
http://www.defender2.net/forum/topic10829.html
My Fault Code...the familiar (now I understand it better...) P1103 Resets after around 6 Engine Run Cycles
(Easy to remove MAF Sensor and Clean)
Good Luck... SKIP
Post #658621 20th Oct 2017 6:01pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I bought one of these a while ago for my puma, very basic but reads faults and clears them for £15 inc p&p. a bargain.
https://www.ebay.co.uk/i/151977163155?chn=...amp;crdt=0
It's got me going a couple of times before the BAS tool and remap.
Thumbs Up Just because you're offended doesn't mean you're right.
Post #658623 20th Oct 2017 6:05pm
^^^^ I had a similar unit to this a while ago also with no problem.
Dealers charge around £40 just to plug in much less anything out.
Possibly £10 per button press too maybe. Whistle Rolling with laughter No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #658625 20th Oct 2017 6:25pm
Farmer58za
That sounds a whole lot better that the standard Landrover response: "That'll be (add large sum here) + VAT"
Cool
Thumbs Up
Post #658636 20th Oct 2017 6:59pm
Farmer58za
Cool
Thumbs Up
Post #658637 20th Oct 2017 6:59pm
Stacey007
First time it happened I took mine to garage..
Then bought an ultra gauge
Great bit of kit reset it myself, use it for engine temp, revs, speed many other gauges.
Only around £60 and small enough to fit in that gap between speedo and rev counter
Post #658642 20th Oct 2017 7:28pm
Farmer58za
I parked the Landy till this afternoon. Started it up and no warning light... Confused Maybe 5 or 6 re-start cycles from first seeing it. That's good news in the short term. I will get some OBD scanner device for the future.
Thanks for all of your input.
Regards
Post #658779 21st Oct 2017 5:10pm
