Home > Puma (Tdci) > Typical: Friday afternoon at 4.30...... |
Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85 |
Hi All
I got an engine malfunction light late this afternoon. No funny noises, performance drop, temperature increase or limp mode. Just a light. I looked at some other threads about restarting a number of cycles to clear the fault, as well as the distinct possibility of it being the MAF or EGR. What's the best cheap diagnostic tool that's available out there? The Foxwell nt204 looks pretty good at less than 50 GBP. Any recommendations? If I don't sort it out over the weekend, I will go off to the local indie LR garage on Monday... Regards David Dave's not here man... |
20th Oct 2017 5:40pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Farmer58za
I have the ScanGaugeII and really like it...bought to answer a similar situation to yours (maybe even the same... ) This is worth a look... http://www.defender2.net/forum/topic10829.html My Fault Code...the familiar (now I understand it better...) P1103 Resets after around 6 Engine Run Cycles (Easy to remove MAF Sensor and Clean) Click image to enlarge Click image to enlarge Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
20th Oct 2017 6:01pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
I bought one of these a while ago for my puma, very basic but reads faults and clears them for £15 inc p&p. a bargain.
https://www.ebay.co.uk/i/151977163155?chn=...amp;crdt=0 It's got me going a couple of times before the BAS tool and remap. Just because you're offended doesn't mean you're right. |
20th Oct 2017 6:05pm |
That sounds a whole lot better that the standard Landrover response: "That'll be (add large sum here) + VAT"
20th Oct 2017 6:59pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3765 |
First time it happened I took mine to garage..
Then bought an ultra gauge Great bit of kit reset it myself, use it for engine temp, revs, speed many other gauges. Only around £60 and small enough to fit in that gap between speedo and rev counter |
20th Oct 2017 7:28pm |
I parked the Landy till this afternoon. Started it up and no warning light... Maybe 5 or 6 re-start cycles from first seeing it. That's good news in the short term. I will get some OBD scanner device for the future.
Thanks for all of your input. Regards David Dave's not here man... |
21st Oct 2017 5:10pm |
