Home > Puma (Tdci) > accelerator pedal
TOP5N
accelerator pedal
Is it just my defender, or is everyone else's accelerator pedal dead for around the first half inch of movement...
(2015 defender 90)
Post #658749 21st Oct 2017 3:25pm
M94PUMA
Nope just yours! Wink
Post #658760 21st Oct 2017 5:01pm
ericvv
Don't know about Td5, but the 2007 onward Pumas have an electronic throttle. Many people have to get used to the slight delay of its response when driving off. Maybe that's what you experience. Easy to get used to though, after a bit of time it all feels just natural.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #658765 21st Oct 2017 5:21pm
Balvaig
Mine is a 2015. No free play in high range, but slower response in low range.
Sounds like a fault.
Post #658768 21st Oct 2017 5:27pm
M94PUMA
No fault, in low range the ecu changes the throttle sensitivity to avoid kangarooing on the throttle.
Post #658774 21st Oct 2017 5:52pm
TOP5N
Thanks for the replies. Perhaps that�s what it is then... just seems odd compared to normal.
Post #658785 21st Oct 2017 6:31pm
NMBRPL8
Australia
Mine doesn't have Quick Launch function either
Post #658847 21st Oct 2017 10:58pm
zsd-puma
is the high/low stick fully in the high position? It might just need a little shove to correct it. ie. it's resting on the switch and fooling the ECU into thinking it's in low range.
Post #658853 21st Oct 2017 11:27pm
