Home > Puma (Tdci) > A little bit of unleaded in a 2.2 puma tank. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I can't see that amount would cause an issue?
If it was me, I would run it down to 3/4 full then fill up with diesel again, and then keep topping it up. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
16th Oct 2017 6:35pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 588 |
My Mrs put £20 in an empty disco4. I put another £60 on top and we didn't experience any issues. No dpf though
16th Oct 2017 6:40pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1790 |
did the same in my 2.4, kept topping it up - no issues at all.
good luck |
16th Oct 2017 6:47pm |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 |
I did the same on my Range Rover L322 1/2 filled nearly £50 worth of petrol just filled the tank to the brim with super diesel or what ever they call it .
16th Oct 2017 6:51pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
I might risk it in my old 200TDi but not in a 2.2 with a high pressure fuel system.
16th Oct 2017 6:58pm |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 |
Yeah it was the DPF I was worried about, tbh. |
16th Oct 2017 7:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
Fill the tank right up with diesel now and you'll lesten any effect of any issue.
That should be fine. No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
16th Oct 2017 7:17pm |
DPF will be fine, seen it done plenty of times. 80" 80" 86" 88" 90"
16th Oct 2017 7:19pm |
All sounds encouraging, thanks chaos.
If someting does go bang, i'll let you know. Apart from the usual suck, squeeze, bang, blow. |
16th Oct 2017 7:39pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I would have been inclined too chuck least half a litre of 2/C oil into the mix asap!
17th Oct 2017 12:46am |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Cold countries run petrol in diesel to stop waxing. Up to 50%.
17th Oct 2017 3:13am |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1035 |
Am I the only driver on here who has never filled up with the wrong fuel?
Just need to be extra careful next time I fill up - pride comes before a fall! |
17th Oct 2017 7:57am |
"Am I the only driver on here who has never filled up with the wrong fuel? "
No, I have never managed to do it, but S.H.M.B.O. did it to both the Disco which was petrol and her 90 which was diesel within 30 minutes of each other. The recovery driver and the Indy tried so hard to keep their faces straight in front of her. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
17th Oct 2017 8:44am |
Really? That'll help too. Lube the pump I guess? |
17th Oct 2017 11:59am |
