Home > Puma (Tdci) > A little bit of unleaded in a 2.2 puma tank.
Page 2 of 2 <12
Dobby
AMBxx wrote:
Am I the only driver on here who has never filled up with the wrong fuel?
Just need to be extra careful next time I fill up - pride comes before a fall! Big Cry
Took me 34 years of driving to do it. I blame it on the pumps. It was a shell, with those new-fangled digital pump handles. And, I'm the person who always checks some joker hasn't swapped the handles around in their holsters too.
Post #657843 17th Oct 2017 1:02pm
jst
How much petrol in the tank do we think you can get away with? 50%? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #657865 17th Oct 2017 1:52pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Think 50% might be pushing it,
I wouldn't like to run it above 30%?
I think you might be in pump damage territory?
Could be completely wrong though.... Question 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #657869 17th Oct 2017 2:38pm
bankz5152
Same, I double and triple check. I almost always follow the line back to the source to make sure its coming from the right one! Luckily me local garage has the fuel type written on the pump handle and petrol/diesel pumps are segregated.
Didnt know throwing some unleaded in the tank was good for emissions! I knew people did it in winter but thats about it
Post #657871 17th Oct 2017 2:50pm
X4SKP
You could always Siphon some (or all) of it out... Question
Thought I'd check... just may be LR have fitted an anti-siphon (gadget / ball) to the Filler Hose, I was fairly sure they hadn't (Security... Laughing ) and sure enough (on a 2.4 Puma) you can get right down into the Tank with a standard length of garden hose.
Now the reality of doing this under the 'typical circumstances' of putting in the wrong fuel, are not as straight forward as it first appears, I'm sure you can't siphon on a garage forecourt, and even if you did the 'push of shame' around the corner, you are then faced with the what do I siphon 40-50 + Lts in to... more on a 110, assuming you have really 'phased out' while filling up.
Dilute down as has been said, but this will not change the % mix in the fuel lines, until the new mix runs through, if it were me I'd be tempted to siphon out as much as possible, as soon as possible, (round the corner) then maximising the Diesel to Unleaded ratio, doing the sums in my head as I went...
Also top up with the higher quality Diesel as this is claimed to have improved Lubrication Qualities.
Some Breakdown Services cover this 'mishap'... Mr. Green (with Green Flag its standard on all Levels of Cover except Rescue only)
150,000 Cases a year apparently, so you are not alone...
Good Luck Dobby Embarassed
Siphoning a Puma... Thumbs Up
 SKIP
Post #657872 17th Oct 2017 2:55pm
ericvv
Post #657878 17th Oct 2017 3:27pm
Dobby
Thanks. I added 70 litres of posh diesel ontop of it, so syphoning that lot out isn't something i'd look forward to. Seems to be running ok sp far. Have added a 2 stroke oil too just to keep the pump lubed up nicely.
on the plus side, even with the posh diesel in, it's running really smoothly. Like having a good splash of miller diesel power in there.
Post #657887 17th Oct 2017 4:10pm
X4SKP
Thumbs Up So you've found your new 'Power Mix' then.
What's the 'take away' from this...(if as you did) start with < 10Lts of Unleaded, into a Tank that presumably
needed filling, would you do the same again... 'drown it' in Diesel, or would you be tempted to get it out... Question
Good to know that a little looks to be 'tolerated' (and progressive dilution can only help) SKIP
Post #657890 17th Oct 2017 4:31pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
AFAIK Phil baylis still runs about 5% unleaded in his well tuned 90 TD5. So it is a known thing to make more power but not enough to make me want to try it though Shocked
Post #657896 17th Oct 2017 4:59pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Older inline type injection pumps are no problem, rotary pumps will sieze bearings and electronic are a gamble. I ran Mercedes trucks when they used Bosch inline injection pumps and the handbook mentioned a 50% of unleaded in severe weather but did add in some countries including UK was an offence under C&E regulations.
Post #657907 17th Oct 2017 5:39pm
zsd-puma
Kerosine was another alternative to prevent waxing, Adding Kerosene (parafin) is an offence, because there's no duty paid on it.
Petrol isn't a problem legally as you've already paid the duty on it.
Post #657919 17th Oct 2017 6:35pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Now my question is will adding a bit petrol be beneficial to the 2.2?
I have heard ppl putting two stroke oil and stuffs in
Post #660191 29th Oct 2017 3:11am
HongKongUKDefender
Hong Kong 2012 Defender 110 Puma 2.2 XS CSW Stornoway Grey
On a reverse note I put about half a litre of diesel into my old Saab 95-5 T and not a bit of smoke a few years back. Did fill it after every 50 miles thereafter.
{btw a Defender 110 owner)
Post #676025 5th Jan 2018 12:31pm
Page 2 of 2 <12
