Home > In Car Electronics > Headlight troubleshooting
Teario
1998 Defender 90 300 Tdi SW Rioja Red
I'm having some trouble diagnosing an issue I've got with my headlights and hoping someone can give me a pointer. It's a 300tdi. I was driving home in the dark and suddenly both headlights went out. The sidelights work fine, it's the main lights which do not work.
If I put the light switch to position 1, I get sidelights. If I push it further to position 2 I still only get sidelights.
On the other light stalk, if I pull it towards me to temporarily flash high beams, I get both high beams. However if I push it the other way for permanent high beams I get nothing.
According to the back of the fuse panel, there are 4 fuses and a relay forming part of the light circuit
First step, I checked the fuses here in the bottom left, the 4 marked 7.5:
All of those were fine, so I checked the relay marked "Head Lamps".
The 2 yellow relays either side of the black appear to be the same layout from looking at the diagram on them, so I tried both of the yellows in place of the black and neither of them made a difference to the lights.
I started thinking maybe it's a coincidence and both bulbs have gone at the same time, but looking at the bulbs they appear fine. I replaced them anyway and the brand new ones also do not work.
So after looking it up on here I saw that it's a common fault for the switch to fail. Here's the switch that was in there:
Kind of difficult to see but there is some heat related damage to the plastic on the switch. I bridged the connection from blue to brown (top left to bottom left) as that's what it looked like the result of position 2 would be on the switch, but again that gave me sidelights and no headlights.
Just to rule it out, I bought a new switch anyway and replaced that. Same deal, both 1 and 2 positions only give sidelights and I have no permanent high beam even with a brand new switch.
Are there any other usual suspects or anyone got any other suggestions? I have no other ideas what it could be so figured I would defer to the far greater knowledge of the forum before I take it in somewhere.
Post #648665 6th Sep 2017 7:14pm
ickle
column mounted main dip switch fail as well, replace switch and fit a relayed loom. Thumbs Up
Post #648667 6th Sep 2017 7:19pm
^^^^ This. But do consider fitting a Relayed loom. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #648686 6th Sep 2017 8:20pm
Teario
Thanks chaps, got a new switch and relayed loom on their way.
Hopefully I'll be able to go out in the dark again soon Smile
Post #649198 9th Sep 2017 8:20pm
Mech
when you say dip switch, are you referring to the main stalk? The one that has the horn on it also?
-Mech
Post #655032 5th Oct 2017 12:33am
Teario
Yep, that's the one.
Post #655660 7th Oct 2017 5:56pm
Petrovich
Russia
Right now I have the same problem with my Puma 2007
Sorry for my poor English (learnt on Essex streets) but I didn't find correct translation for "RELAYED LOOM"
Do you mind guys to explain meself
If with pictures - would be excellent! Defender 110 '07
Post #655760 8th Oct 2017 1:14am
Alien
Australia
A relayed loom reduces the current through the switch.
A couple of examples...
http://www.paddockspares.com/boomslang-per...-loom.html
http://www.traxide.com.au/headlight-wiring-kits/ Cheers,
Kyle.
Post #655761 8th Oct 2017 1:53am
Petrovich
Russia
Alien
TA! Defender 110 '07
Post #655774 8th Oct 2017 7:23am
