![]() | Home > In Car Electronics > Headlight troubleshooting |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1851 ![]() ![]() ![]() |
column mounted main dip switch fail as well, replace switch and fit a relayed loom.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
^^^^ This. But do consider fitting a Relayed loom. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Teario Member Since: 04 Aug 2015 Location: Merseyside Posts: 153 ![]() ![]() |
Thanks chaps, got a new switch and relayed loom on their way.
Hopefully I'll be able to go out in the dark again soon ![]() |
Mech Member Since: 23 Oct 2013 Location: Oxfordshire Posts: 87 ![]() ![]() |
when you say dip switch, are you referring to the main stalk? The one that has the horn on it also?
-Mech |
Yep, that's the one.
Petrovich Member Since: 24 Jan 2008 Location: Sankt-Peterburg Posts: 75 ![]() ![]() |
Right now I have the same problem with my Puma 2007
Sorry for my poor English (learnt on Essex streets) but I didn't find correct translation for "RELAYED LOOM" Do you mind guys to explain meself If with pictures - would be excellent! Defender 110 '07 |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
A relayed loom reduces the current through the switch.
A couple of examples... http://www.paddockspares.com/boomslang-per...-loom.html http://www.traxide.com.au/headlight-wiring-kits/ Cheers, Kyle. |
Alien TA! Defender 110 '07 |
