Home > Puma (Tdci) > Eratic Idle especially when cold
Page 9 of 10 <12345678910>
OleDave
United Kingdom 2007 Defender 90 Puma 2.4 CSW Indus Silver
Sorry item 1 Nevillerover, think I got that wrong looking at the picture quickly.
Ole Dave
Post #655584 7th Oct 2017 10:14am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Thanks Dave, I appreciate your help.
Diagnostics didn't really show anything, a historical failure to communicate wit e ECU and an unspecified instrument cluster problem.
I'll fit a new VCV and I understand I have to do a fuel pump relearn, hopefully my cheap OBD thing wil do it or I'll go to a garage.
Garage did an injector relearn today and it failed to do one injector. Whether that is connected to my prob or even means I've got an injector on the way it, I don't know.
Anyway, VCV first I think.
Post #655637 7th Oct 2017 5:15pm
OleDave
Hi Nevillerover, The big problem is Land Rover and Ford in their wisdom did not incorporate a trouble code for the fuel vapour valve (SCV) if its faulty even when on diagnostics it cannot see the valve so its not going to flag up even if there is a fault.
Re your cheap OBD adaptor, if its suitable and works you should be able to clear any error codes after fitting and avoid a garage visit.
Regards
Ole Dave
Post #655790 8th Oct 2017 9:46am
Nevillerover
I can clear codes with it Dave but not do a pump relearn. From other forums it seems that it mustn't be driven without the relearn or it damages other components......unless you know different?
Post #655835 8th Oct 2017 2:35pm
OleDave
Hi Nevillerover, the process is in fact called a recalibration, which I doubt your cheap OBD2 adaptor will be able to perform, as mentioned by others I would take your vehicle to a garage that have equipment that can perform the recalibration for you, a cheap OBD2 adaptor will not have the facility I doubt, it takes moments to do as I have watched them carry it out myself, basicly its an accept item Yes or No programme.
Regards
Ole Dave
Post #655863 8th Oct 2017 5:04pm
jst
SVC and pressure relief valve should both be changed at the same time i have been informed. did they change the valve on yours at all? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #656036 9th Oct 2017 11:25am
Nevillerover
I've not read anywhere that the pressure relief valve should heal so be changed, so i haven't. It's probably a lot easier than the bar steward VCV / SCV tho, right awkward job and I damaged the retaining pip on the connector getting it off so I've now gaffer taped and cable tied it on to make sure. Regardless, it's done now and I will report back once calibrated at my local friendly garage.
Post #656422 10th Oct 2017 8:14pm
jst
thats what i picked up from a diagnostic specialist, the guy LR take the vehicles to when the dealer cant fix it. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #656440 10th Oct 2017 9:05pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
If its been a case of erratic revs due to sticky SCV then it's very unlikely the pressure relief valve has blown. Garages will change them at your expense as they are not paying and can't be bothered to test them. The SCV is a proportional valve so the calibrate process updates the look up coefficients stored in the ecu so it's not just a check. It's a process of changing revs and adjusting the SCV opening position to get the correct fuel pressure at the rail. "You are never to old to learn something new"
Post #657347 15th Oct 2017 8:57am
Zed
Reading this thread with great interest as i think my puma may be suffering the same issue. Unfortunately most of the conversation is going over my head but hopefully i will be at least better informed when I take it to the garage.
Post #657353 15th Oct 2017 9:32am
OleDave
Hi zed, never ever be afraid to ask!!! if the thread does get technical and into depth there is always somebody on this wonderful forum who will take the time to help you and explain things in a basic format so all can understand.
Regards
Ole Dave
Post #657361 15th Oct 2017 9:59am
Zed
Cheers Dave. Much appreciated. I have to say this is a very friendly and informative forum. I wish I'd known about it when I first got my Defender. Would have saved myself a lot of hassle and probably cash too.
Post #657428 15th Oct 2017 4:54pm
Nevillerover
So, having changed the VCV/SCV, the local garage attempted a pump and injector re-learn for me.
They couldn't get the pump to Learn because it kept saying it needed to be up to temperature which it was already.
Anyone have any suggestions please?
Post #657983 17th Oct 2017 9:34pm
agentmulder
Kuwait
If you're in a cold location it's just dropping below the required temp as the test progresses.
Take it up a bit warmer initially (drive up a few hills with the radiator covered?), and/or do it in a warmer space. Solved the bowel problem, working on the consonants...
Post #658015 18th Oct 2017 5:38am
OleDave
Hi Nevillerover, thats an odd one! I was in attendance when the technician coupled up the Bosch diagnostics on the first occasion following the svc change and the engine temp would not have been up to the max and there was no problem in carrying out the calibration, I will if I can get hold of the technician have a chat with him about your problem and come back to you with his remarks.
Regards
Ole Dave
Post #658033 18th Oct 2017 8:58am
