Home > Puma (Tdci) > Eratic Idle especially when cold
Page 7 of 10 <12345678910>
jst
http://www.defender2.net/forum/topic26346.html
this post Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #651826 21st Sep 2017 3:28pm
OleDave
United Kingdom 2007 Defender 90 Puma 2.4 CSW Indus Silver
Hi B4lamb thank you so much for your swift reply, I have worked on many cars with EGR problems but never have I come across one that causes the syptoms I am seeing, in saying that I am no expert on modern controls, my suspicion is that the new fuel vapour control valve is possibly faulty, many times have I seen new parts fitted which have turned out to be faulty, when replaced with another spare the problem has cleared.
I have just come back from a trip out looking for an obscure hairdresser for the wife!!! and thought it a good idea to give it another run to see what happens, after about 5 mins running and stopping at a set of lights it did display some eratic idle but then cleared, following that it ran like a watch, Odd or what ??
Forgive me as I am not quite sure what your referring to when you say Chugga Chugga, anyway can you advise more detail on the cheapo OBD fault code resetting tool you bought as I might buy one.
Regards and many thanks
Ole Dave
Post #651835 21st Sep 2017 3:51pm
zsd-puma wrote:
... I was under the impression [the PRV] was just a spring loaded valve, similar in principle to a rad cap. ie. pressure goes too high it opens, once it drops back down it closes again?...
I believe that it is actually a ball bearing crimped onto a seat. When the pressure rises to a set point, the crimp fails and the bearing comes out.
EGR problems are common on the TDCi motor, but (unlike VCV problems) usually produce DTCs (one of the pointers to a problem being the VCV is an absence of DTCs.) A EGR valve stuck open will impact the running, and will have most impact at low engine speeds. An erratic tickover is a known symptom of an EGR vavle failing to close.
It is also a fallacy that the EGR valve should make the "chukka chukka" sound when self-cleaning on engine stop. A perfectly-working EGR is almost silent in operation and you'd have to losten very carefully to hear it. Perfectly-working EGRs are very rare (I've only met about 2 that are quiet in the last 10 years), and the noise is common. So the "chukka chukka" is normal rather than correct, but it does indicate that the valve is operating although it doesn't necessarily mean that it is operating correctly, nor closing fully.
As a general diagnostic rule on the TDCi, if the engine is running badly, misfiring, losing power, and has a rough tickover look for DTCs. If none, suspect the VCV. If there are DTCs relating in anyway to EGR, suspect the EGR, or if there are DTCs relating in anyway to manifold pressures, overboost, underboost, etc, suspect the intercooler pipes, turbo actuator, MAF or MAP sensors, or possibly EGR, although these are less likely to cause rough tickover.
Post #651868 21st Sep 2017 5:50pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
As I said I'm not convinced the egr can cause the erratic idle and stalling problem in the first place so even if it is not fully closing with its extremely strong spring action then it's going to be a constant small gas leak so why would that cause erratic engine revs when it's held in a constant position? Whereas, when it's electrically connected it's valve position will be changing under control of tge ECU although to be fair it only really opens during deceleration or when the load is taken off the engine. By removing the control to the EGR you are effectively taking away another variable so if there is no change to the problem it's unlikely to be the cause. Taking the egr out to see that it is closing would be one certain way to eliminate your identified possibility but it's a pig to get in or out so I would try my simple suggestion and see what result you get. "You are never to old to learn something new"
Post #651869 21st Sep 2017 5:53pm
jst
understood, thank you Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #651874 21st Sep 2017 6:11pm
B4Lamb
Quote:
It is also a fallacy that the EGR valve should make the "chukka chukka" sound when self-cleaning on engine stop. A perfectly-working EGR is almost silent in operation and you'd have to losten very carefully to hear it. Perfectly-working EGRs are very rare (I've only met about 2 that are quiet in the last 10 years), and the noise is common. So the "chukka chukka" is normal rather than correct, but it does indicate that the valve is operating although it doesn't necessarily mean that it is operating correctly.
The EGR valve has a crude gearbox, a 12 v electric motor drives a small sprocket on the end of the motor shaft the then turns a larger gear on the valve shaft. A cam type action converts rotary motion to a linear pull of the valve against a strong spring. It's hard for the crude gearbox not to make an audible noise when the cleaning cycle rapidly opens and closes the valve fully 4 times at engine off.
It's easy to test the EGR is doing this action but unplugging the connector to it and then connecting 12V across the motor pins in the EGR connector. They are the two pins that are on there own. If you get the polarity wrong the motor will just try and drive it hard into the closed stop position and you will not hear it operate but if you reverse the connection it turns the motor in the correct direction and it will fully open the valve. On removing the 12V you should hear it wind itself back shut under the spring action. In one of my posts there is a photo of the connector pins you connect to. Note you need about 4 amps at 12V if you are using an external power supply. A standard car battery charger should be sufficient. "You are never to old to learn something new"
Post #651879 21st Sep 2017 6:30pm
OleDave
Hi Guys, well some very useful information from all so thank you very much for all the replies, I am asuming that if a fault code is showing re the egr valve that the fault relates to either the valve not opening or not closing correctly or that the gas flows are incorrect due to either of the aforementioned? has anyone ever had these valves to pieces for a good scrub? have done that a few times on other makes of vehicle with some success, have seen a few totally choked with carbon along with the pipework, at that time stripdown was done due to lack of performance and or pumping out black smoke but as far as I can remember none were dismantled or replaced due to eratic idle or cuttting the engine out!
Regards
Ole Dave
Post #651897 21st Sep 2017 7:46pm
B4Lamb
Yes OleDave, I've had a few apart.
They are not that complicated. See post "EGR Fault" at http://www.defender2.net/forum/topic47507.html in my case all the ones I've looked have just had light sooting around valve seat. You have to prize open the outer case tabs to get access to the motor and gearbox. It's that thread you will find details and pictures of the gear train. The EGR faults are derived from detected anomalies in air flow but also there is a position sensor I believe in the EGR itself but I've yet to find details of that. The other 3 pins in the connector I assume are to do with that. The opening position of the EGR valve is controlled using a variable pulse width control signal from the ECU, you need an oscilloscope to look at the signal. I'll try and post something on it so members who are interested can get more knowledge. I believe the sensor is a non contact hall effect type that measures the magnetic flux or reluctance change as the large gear rotates. I'll try and find out more. I'd like to get hold of more example EGR valves as I think most are serviceable. "You are never to old to learn something new"
Post #651910 21st Sep 2017 8:36pm
B4Lamb
Ole Dave
This is the link for the Torque App about 4 quid.
http://www.androidauthority.com/torque-app...bd2-95772/
Here is a link for the bluetooth OBD2 Scanner plug in unit.
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
There are loads of these on ebay so if the link fails with time just search OBD2 scan and you will find one. I had to cut away a bit of the plastic trim above the accelerator pedal where the OBD connector is located as there was not quite enough room to fit the bluetooth OBD2 plug. I leave it in place all the time.
The chugga chugga or chukka chukka is the sound that "most" EGR valves make a few seconds after turning off the engine when it is put into its cleaning sequence. If it's dead quite then it's either a perfectly manufactured example or its not working. If you want to amplify it, stick a long screw driver on it, listen with the handle in your ear and get someone to turn off the engine. "You are never to old to learn something new"
Post #651923 21st Sep 2017 9:01pm
The 'chugga, chugga' sound is the EGR self cleaning cycle that happens just immediately after engine shut down.
If you have a remap with the EGR shut down, this can be disabled as well or cleaning cycle operational only but still electronically blanked shut.
I decided to have mine shut, and the EGR cleaning cycle turned off also. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #651931 21st Sep 2017 9:28pm
B4Lamb
Do you have to inform your insurers if you have the EGR effectively turned off by a change to tge ECU even though it doesn't make much difference to performance? "You are never to old to learn something new"
Post #651954 21st Sep 2017 11:12pm
OleDave
Hi B4lamb and guys, many thanks for the info B4lamb, I sorta guessed the valve would have a variable control depending on the conditions, Ah! I now understand what your saying the chugga chugga from the valve when the ignition is turned off, will have to get the wife primed one day soon when its not raining and listen to the valve working (Or Not) and make a decision on whether to strip or replace, obviously replace is the easiest of the options for me but the most expensive as I have checked LR and they are around £190 plus vat.
In conclusion on the issue again of EGR problems, I was advised by my garage that they have a useful chap who is a good all rounder in the control department that they use from time to time, it appears he can blank out the ECU from seeing the EGR valve altogether plus stop the Engine management light showing if disconnected, but I am am worried that doing that might cause other problems, what are all your thoughts on blanking off the EGR system and letting the engine breath constant fresh air?
Have looked at your link and will get an OBD2 adaptor and the App soon as it looks a useful tool to have, many thanks for the lead on that, it would be very interesting maybe one day to meet up with you for a general chat re: the defender, we occasionally visit the Brecon Beacons Caravan club site outside Brecon as its only 50mins from where we live, maybe the next time we are up there and if your free we could meet up for a chin wag and a coffee?
Regards
Ole Dave
Post #652000 22nd Sep 2017 8:46am
Yes, it's a modification and you are contractually required to tell them. Your policy could be invalidated if you do not.
That being said, I doubt that many people do. It is hard to see how it alters the risk, and how would the insurer know if the EGR was working or not?
Post #652029 22nd Sep 2017 10:34am
B4Lamb
Quote:
...... it appears he can blank out the ECU from seeing the EGR valve altogether plus stop the Engine management light showing if disconnected, but I am am worried that doing that might cause other problems, what are all your thoughts on blanking off the EGR system and letting the engine breath constant fresh air?
There are conflicting opinions on blanking or disabling the EGR function. Some say that reducing the combustion temperature that produces the Noxious Nitrogen Oxide (NOx) that the EGR function is designed to reduce in the emissions has a beneficial effect to engine life and while others that I tend to side with say that allowing carbon deposits back into cylinders has a negative effect of wear in the cylinder bores and degradation (blackening) of the engine oil as well as the build up of soot and tar in the inlet manifold and vacuum tubes. There is a good article on the subject in Wikipedia worth reading https://en.wikipedia.org/wiki/Exhaust_gas_recirculation "You are never to old to learn something new"
Post #652070 22nd Sep 2017 1:19pm
OleDave
Hi 4Blamb and guys, On the topic again of EGR valves, I have just come back after a trip out shopping so the Defender engine was up to temp, I pinched the wife's stethascope which she uses during clinics for patients Rolling Eyes I had her turn off the engine while I did a listen to the EGR valve operation, it does exactly what you mentioned and does the chugga chugga although to my hearing it sounds more like a hen scratching around in the dirt 4 times lol.
If that signals its going through its cleaning cycle and working I am confused why on the garage computer it shows up a faulty EGR valve, I suppose that could mean a number of things such as the valve bypassing gasses, not fully opening or fully closing? any suggestions?
Ole Dave
Post #652404 24th Sep 2017 11:49am
